01-27-2018, 02:08 PM | #1 |
4 speed crash box - bearings
This may be listed elsewhere and maybe no one cares but I disassembled a GM 1946 -- 4 speed crash box and have the following bearing list:
Input shaft to mainshaft pilot -- Open Roller cage - no number found - have not found- .875" ID x 1.25" ODx 1.5 " long ---- I need to clean up the mainshaft pilot so I will lathe it to .75" and hope to use a Koyo HJ-122016 open needle roller bearing. It has an outer case that may solve any female input shaft issues. .75"x1.25"x1" long Input shaft bearing -- FAFNIR 209K Rear Mainshaft --- New Departure 3307 Front Countershaft --- Hyatt ORB 1206 Rear Countershaft ---- Hyatt ORB 1207 Feel free to update or correct this list and add any cross references, etc.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 01-28-2018 at 09:42 AM. Reason: words |
01-28-2018, 09:38 AM | #2 |
Re: 4 speed crash box - bearings
The fit of the Koyo is just a bit more than a slip fit into the input shaft... nice. Should be able to pull it easily with a pilot bushing puller. Again I will lathe the mainshaft pilot to .75 inch.
There are probably some of the originals nos open roller cage bearing out there. Has anyone removed the rear main shaft bearing -- new departure 3307--- with a bearing seperator and not destroyed it? Or does the inside snap ring on the shaft push the bearing off?
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 01-29-2018 at 09:08 AM. Reason: words |
