Old 01-27-2018, 06:37 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Questions on Power Steering
I just had a couple of questions.
One is does this steering shaft look like a 3/4"-30? with the flat side and all I wasnt sure.
And the other is what type of hose fittings are these? O-ring?
Old 01-28-2018, 12:36 AM   #2
Captainfab
60-66 Nut
Re: Questions on Power Steering
Yes that is a 3/4" diameter shaft. I can not tell if it is 30 spline or 36. If you count the splines at about half way around that will tell you. That box accepts SAE inverted flare hose fittings
Old 01-28-2018, 10:55 AM   #3
The Rocknrod
Moderator
Thank you Captainfab, always helpful.
So this would show 30.
Old 01-28-2018, 01:14 PM   #4
padresag
is this a difference between 3/4 t and 1/2t? I have the larger one on mine. when I went to replace it once and ordered one it came with the smaller spline. had to reorder to get the correct one. vintage was 76 4 x 4
ron
padresag is offline   Reply With Quote
Old 01-29-2018, 12:26 AM   #5
Captainfab
60-66 Nut
Yep, looks like it is 30 spline.
Old 01-28-2018, 04:03 PM   #6
The Rocknrod
Moderator
I think if you look in Rock-Auto and bring up both units it would show if there is a difference, that's what I would do.
Old 01-28-2018, 04:23 PM   #7
padresag
I am not looking for anything, but commenting on the differences which I found about 20 years ago
ron
