Old 01-27-2018, 07:26 PM   #1
superhondaz50
superhondaz50's Avatar
6 tab flexplate?
So I just got my 12" ACC th400 6 tab torque converter, I also received my flexplate from rock auto. The flexplate only mates up with 3 tabs, can I enlarge the other three holes on the flexplate to fit TC?
superhondaz50 is offline   Reply With Quote
Old 01-27-2018, 07:59 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 6 tab flexplate?
Does it really need to have all 6 holes bolted up? There shouldn't be any issues opening the other holes up, but I'd recommend making sure that they are smooth so cracks don't have a place to initiate from.
~Steven
Simi Valley, CA
Old 01-27-2018, 08:54 PM   #3
superhondaz50
I'd like to have all 6 if possible. Anyone have the part number for a flexplate with 6 correct holes for a 350 engine to th400?
Old 01-27-2018, 08:58 PM   #4
truckster
truckster's Avatar
Are you sure it's not a dual bolt pattern? Early flexplates were SAE pattern and later ones are metric.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 01-27-2018, 11:08 PM   #5
superhondaz50
Ya, it's a dual pattern flexplate, 3 @ 11.5, 3 @ 10.75, need 6 @ 11.5
Old 01-27-2018, 11:19 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
How much torque does your engine put out? A 454 truck still only uses 3 bolts from the converter to the flex plate. I think you are chasing your tail with using 6 bolts.
~Steven
Simi Valley, CA
Old 01-27-2018, 11:54 PM   #7
superhondaz50
250hp 350ftlb, it's really low. So it should be ok leaving three tabs with no bolts? Still need to find some 3/8-16 Bolta for it too.
Old 01-28-2018, 01:57 AM   #8
truckster
truckster's Avatar
Three bolts. That's all it needs.
Old 01-27-2018, 11:51 PM   #9
truckster
truckster's Avatar
You only need three of those bolts. That's all they're designed for. The dual pattern is so you can use the converter with either flexplate.
I would be concerned about damaging the flexplate if you redrill or enlarge the other holes.
Old 01-28-2018, 06:48 AM   #10
superhondaz50
Sweet, thanks!
Old 01-28-2018, 06:48 AM   #11
superhondaz50
BTW, do you use lock washers or lock Tite?
Old 01-28-2018, 08:46 AM   #12
Bigdav160
Bigdav160's Avatar
Either works.
BTW, one tone trucks with 350/th400 combinations used 6 bolts on the torque converter.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-28-2018, 11:09 AM   #13
superhondaz50
Good to know the 1 ton thing. Mines 1/2 ton.
Old 01-28-2018, 01:54 PM   #14
ZEKE68
ZEKE68's Avatar
Some later trucks used six bolts. I found a Pioneer FRA-145 flex plate on ebay which had six 11.5 holes for a 454. It was an old leftover and they don't list it any more. Now they list a FRA-141 for the 454 which is a dual pattern with 3 @ 11.5 and 3 @ 10 3/4" and the hole are very large in it.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 01-28-2018, 04:23 PM   #15
superhondaz50
Cool, I'm gonna keep an eye out for that, if I can't find it I'll just use three bolts for the time being
Old 01-28-2018, 06:15 PM   #16
truckster
truckster's Avatar
Cool, I'm gonna keep an eye out for that...
I wouldn't do that. The 454 is balanced externally and SBCs are balanced internally (except the 400). The 454 flexplate has a balance weight on it, and you're going to have a heck of a vibration you just can't get rid of.
Just use the three bolts. It's how it was designed to run.
