01-30-2018, 02:25 AM | #1 |
Speedometer Ratio adapter
I have a discrepancy between my speedometer and the actual speed because I changed out to bigger tires. I know that I can install a speedo gear ratio adapter to correct the discrepancy. It is off about 10% (Reads 60 when Im only doing 55). The question is finding out the correct ratio. I have a kit that I purchased recently that I can use to build the needed adapter and it came with many different gears but unfortunately the instructions are vague or non-existent. Any help would be greatly appreciated.
thanks, kevin
My Paypal address is: http://paypal.me/KFerguson66 72 K20 Cheyenne Super My "re-build" thread http://67-72chevytrucks.com/vboard/s...?t=710221&goto Thread for my Reproduction Jack Bags http://67-72chevytrucks.com/vboard/s...d.php?t=715455 |
01-30-2018, 08:22 AM | #2 |
Re: Speedometer Ratio adapter
We downloaded a GPS speedometer on our phone set it in the windshield/dash and changed one gear at a time til we got it spot on. After you put one you will know more or less the directions you'll need to go. Or call the guys at trans star. They are alot of help.
01-30-2018, 11:24 AM | #3 |
Never been inside one, I'm assuming there are three gears - drive, idler, driven? If so, are the idlers all the same tooth count? If they are you can calculate output by dividing the drive gear by the driven gear. If the idlers have different tooth counts you can still calculate, I'd have to look it up, I do all my math on my fingers!
01-30-2018, 11:36 AM | #4 |
Can't you just change the driven gear (and maybe the drive) in the transmission? That would seem a lot cheaper than a ratio adapter-and less moving parts to wear.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
01-30-2018, 02:15 PM | #5 |
There are websites that offer "speedometer gear calculators". You'll have to know...
number of teeth on the drive gear (in tranny), tire diameter, and rearend ratio. If you have found your truck to be inbetween somewhere then the ratio adaptor may be your only hope.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
01-31-2018, 08:40 AM | #6 |
I bought a set of the plastic speedo gears of eBay.
Tried a few until I got one that read correctly. Simple to change and only takes 5 min to swap out. Download free phone app for mph and test that way. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
01-31-2018, 12:05 PM | #7 |
Thanks for all of your input folks. I will look into solving this discrepancy with the info provided.
01-31-2018, 12:20 PM | #8 |
I had one of those multi adjustable adaptors once. Never got it close enough. Tried the gear change in the tranny and that was a pain in the butt.
Since then I’ve used adaptors from these guys. They have it all. Gears, calculators etc. https://transmissioncenter.net/ |
