Old 01-31-2018, 06:43 PM   #1
irl104
Front Sway Bar question
I have a 1968 Chevy one ton wrecker and it doesn't have a front sway bar on it. I'm not that familiar with this and what it is for.
Can I install one on it?
Should I install one on it?
Will it help with the handling while driving it?
Should it be the 1" or the 1 1/4" bar kit?
Thank you for any education in this matter.
irl104 is offline   Reply With Quote
Old 01-31-2018, 07:09 PM   #2
harpo231
harpo231's Avatar
Re: Front Sway Bar question
reduces body roll in turns
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 01-31-2018, 07:29 PM   #3
68 P.O.S.
Yes, it's used for body roll. In a nutshell, it helps to keep the truck level in turns by tieing both sides of the suspension together. You definitely want to go with the 1 1/4" bar
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 01-31-2018, 07:45 PM   #4
ryans69chevy
What I've read it's a huge improvement. I installed an 1-1/4" on mine. My build isn't done yet so I can't tell you the differences in driving. I would use this sites search engine and read about it. I believe TXFIREFIGHTER did a FAQ on it as well where he took pics of everything and even listed the Moog part number for new bushings that you can get at any local parts store. That's where I got the part number for the bushings I bought. They fit pretty good.
ryans69chevy is offline   Reply With Quote
Old 02-04-2018, 12:23 AM   #5
Z10
Z10's Avatar
One of the single best modifications I did on my truck....period. I'm now running front and rear. It will transform your driving experience.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 02-04-2018, 01:23 AM   #6
bbrriiaann1973
I installed a aftermarket on my 70 c10 and it works great
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
Old 02-04-2018, 03:29 AM   #7
bennylava
bennylava's Avatar
I know my 87 needs one. The body roll is... not good. Body roll gets annoying pretty fast. Even just under normal driving conditions.
bennylava is offline   Reply With Quote
Old 02-06-2018, 03:13 PM   #8
irl104
Thank you all for your comments and input.
