Vintage Evil
71 blazer heater/defrost box
Anyone seen a box like this? The left side looks different than any I have seen before...
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax Last edited by chevyguy_72; 02-02-2018 at 12:27 AM. |
Re: 71 blazer heater/defrost box
Looks like "heater delete" option.
Vintage Evil
There is a flapper inside of that box and a slot cut in the bottom and each corner... You can kinda see them in the pics...
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
Yeah, but there's no fan. Even with heater delete, laws back then still required some sort of defrost. Even vehicles with heater delete, will still have a heater core. Not sure how GM did it, but I'm familiar with Mopars of the 60's
#5 | |
Vintage Evil
The fan is on the firewall next to the heater core... The only thing under there is the box with all the flappers.
![]() Join Date: Mar 2004
Yea, but if you put a fan on the firewall, then turned it on...where is it going to blow? - not in that box because it's not connected to it in any way.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
#7 | |
Vintage Evil
This has the same engine bay heater core/fan unit... i was just showing the first pic to show that its a non AC unit... The stock located fan will blow through the heater core and into the cab portion of the heater box... my only question is the reason for the different shaped unit that disperses the heater and defrost.
Vintage Evil
Sorry but that doesn't make sense to me since it actually has heater ports on the bottom and sides? A delete to me would be no heater at all... maybe just a defrost unit... this still has both and a flapper inside to control between them with all 3 wires and the same controls as the other unit...
Whatever you have there apparently did not come with that truck because I can see the mounting holes where the original box was mounted. Are there provisions for a heater core inside the box, or any sign of openings that heater hose could have been routed into? Otherwise that box is pretty much worthless as a defrost without a fan, and worthless as a heater without a fan and source of heat.
