Kinda OT but....
My 95 GMC seems to turn over alot (6-8 times)before firing in cold weather... any suggestions on whether it's an ignition prob or how to get it to fire sooner?
Formerly yellow72custom
Every TBI motor i have seen turns over alot in cold weather to start.....of course that is Missouri cold (like 25 degrees F)
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
student wrench turner
my 69 turns over atleast 15 times so i would consider you kinda lucky. But i think mine is because i dont have a choke.
1969 Chevy C-10 with 250 L6 2002 GMC Sierra 2500 HD Duramax with banks six gun |
Yeah, colder weather is upon us. I can tell because my truck needs to be started twice now. Seems to just bog on the first try. But I like to warm up the truck naturally, ie. letting the choke do its thing, not like my neighbor. He fires it up and then "forces" it by leaning into the gas. Not good for the engine and I keep trying to reason with him but some habits die hard.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
It's just a check engine lamp.
The TBI will take a little longer to fire up. Are you holding down the gas pedal? If so, that could be one of your problems. Holding down the gas pedal in an FI vehicle will enter the "clear flood" mode. It basically has the throttle wide open and allows more air to enter than fuel. This is used in case the engine flooded. I hope this helps. John
Active Inliner---bigchevy66 68 SWB Stepside 250 L6/3 on the floor/ Hedman headers, HEI, MSD 6A box, K&N filter, Offy intake and Edelbrock 600cfm 4 barrel Soon to have: WC T-5 five speed 66 SWB Stepside-undergoing restoration |
Member since 2000
Have you thought about adding a MSD?
68cst_ss490
whens the last time u had a tune up on it maybe it needs plugs, wires and a fuel filter. You can press the gas pedal on a fuel injected, about 1/4 of the way down is enough, it will not enter clear flood mode as suggested. clear flood is entered when the accelerator is held to the floor.
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
Mine always fires first try, even in the cold. This morning it was realy cold and fired right up, it must have been 68 degrees outside Brrrr!
Sorry, couldn't resist. We tolerate the heat for months on end just to get weather like this. I think it cooks our brains too.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
My wife's truck (2000 Silverado) was starting hard too. It turned out to be a collapsed fuel line.
Martin Gibson
USAF Retired 1964(-ish) C10 |
I don't touch the gas at all when starting it. It jsut turns over alot...was jsut wondering if it was something going in the starter or something. I'll have to start plugging it in soon I guess! Jeez it's only November!!!!
I was curious if you guys in Canada use block warmers on your old trucks?
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End Early Classics 6 Lug Disc Brakes and Spindles All Stainless Lines |
its all about the +6 inches
One thing to look at Shawna, do you hop in and crank it over, or do you hit the key, let the fuel pump prime the system, and then crank it?
If you do the latter, then try waiting 5 seconds after hitting the ignition before cranking it over. |
I always wait Andy darlin! Usually gotta wait til my thumb unfreezes from the metal key!
Cool. Most ppl don't know that.
This woman never stops amazing me. ![]() |
#15 |
yeah, i use a block heater. cant hurt in my opinion. just nice to know that things are a little warmer when i turn the key. puls i use a pan warmer to. at -40, nothing hurts
2003 yamaha raptor. Stock, but it still hauls!!!! 2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow. 72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon. "dont let yer mind wander, its to little to go places by itself." "Forget the herse, cause i'll never die"-ACDC Back In Black "If It's To Loud, Yer Just Too Old" "I Love Anything Fast Enough To Do Something Stupid In" "Instant idiot, just add beer!!"" |
#16 |
user # 2756
![]() Join Date: Jun 2001
Dubiette, What's the deal with the duck in your avatar? I keep waiting for the shark to pop through the ice and eat him!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
#17 |
Those are polar ducks. The one on the right has a bad attitude.
#18 |
Have you checked the battery for age and cranking amps.....
The duck on the right may have a bad attitude........but the one on the left is either drunk or is accident prone........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
#19 |
They're penguins!!!
I haven't checked the battery yet, but maybe I should. |
#20 |
Ms. Dubie,
I have a 95 GMC Jimmy (4.3 w/CPI) that was doing the same thing. Mr. Goodwrench said the EGR valve needed to be cleaned and the gasket under the CPI replaced. Said that some crusty stuff was preventing the injectors from shutting off completely, so it would bleed off all the pressure in the system and also drip raw fuel instead of atomized fuel. Your TBI is probably different, but it may be worth a shot to clean & check the EGR and see if anything else on the TBI is crusted over. Good Luck!
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab |
