02-07-2018, 01:06 PM | #1 |
35" tires with 3.73 gears
I currently have 3.73 gears pushing 35" tires down the road. I am considering upgrading to 4.56 gears but am afraid I will lose my 65+MPH highway driving ability. I was curious what options, if any, I may have to possibly add a fifth gear to my stock 4 speed manual transmission.
Any thoughts? |
02-07-2018, 01:15 PM | #2 |
Re: 35" tires with 3.73 gears
split the difference and do 4.11s?
Do you not like the sluggishness off the line with 3.73? Seems to me a trans swap to get that 5th gear would be the most work of your options. |
02-07-2018, 02:01 PM | #3 |
Im running 3.73 with the sm465 and 35s, it goes pretty good for me. I agree with the above statement though. move up to 4.10s and you should be good to go
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
02-09-2018, 11:42 AM | #4 |
My blazer has pretty much the same setup but I am running 33s. However, I feel like on the highway the RPMs are way to high. At 65 MPH i am at 3500 RPMS continuos. Which I feel is way to high. I have thought about getting a NV4500 for the 5th gear set up. I am also swapping to 3/4 ton axles and I believe the rear is 4:10 or 4:11. I feel like that setup would be more suitable for hwy/street
02-09-2018, 12:26 PM | #5 | |
02-09-2018, 12:35 PM | #6 |
02-07-2018, 07:41 PM | #7 |
4.11's may be the easiest, most cost effective way. Doesn't seem like much of a jump from what i have. Do you think i will see a noticeable change?
02-07-2018, 08:09 PM | #8 |
Randy's calculator shows 2565 rpms at 65mph with 35" tires with 4.11 rear gear
https://www.ringpinion.com/calculators/Calc_RPM.aspx
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-07-2018, 09:01 PM | #9 |
Transmission? 3.73 and 35's should be a decent combo. I run 35's with 4.10 and SM465 in my Jimmy. The Jimmy we are screwing together for my teenager is getting 3.73 with a TH350. With converter slippage, they are both probably equal in terms of highway RPM.
Maybe a cam swap to get a little more cruising RPM torque will make the difference and a lot cheaper than swapping gears in both ends. Dual exhaust, HEI and good tune.
02-07-2018, 10:04 PM | #10 | |
Posted via Mobile Device |
02-07-2018, 10:18 PM | #11 |
I did ring and pinion swaps in my truck in the late 80's. I think I broke the 12 bolt in some way 8 or 9 times? My truck has a semi-float 14 bolt from an '86 3/4 ton Suburban and we just pulled a set of 3.73 geared axles from an '84 Sub for my kids project. Both of the 9.5" axles have Gov-Locks in them and we are putting a TransAm clutch posi in the front of his.
I can't see spending $1000 to re-gear your axles and less it is REALLY important to you. But you can probably find a beater Suburban and pull the 8 lug axles from it. (I paid $300 for the 4.10 equipped truck that was equipped with HD towing an TH400. The 3.73 truck had a TH700R4 and was $200.) As you can see, if it were mine I would also be looking for a strength upgrade at same time.
02-07-2018, 10:01 PM | #12 | |
02-09-2018, 08:23 PM | #13 |
i was hoping i could get by with one of these, but with the short wheel base, the driveshaft angle would be too extreme. These add 13" to the rear of the transfer case. The NV4500 may be the best option long term.
http://www.gearvendors.com/4x4.html |
