Old 02-08-2018, 02:28 PM   #1
bcwilson_1
Complete LS3
OK guys I have searched the different threads on this but haven't seen a specific completed LS3 swap done on a 67-72 truck that has a parts/mods list with cost to complete. For those of us that want to take the easy route (for lack of time) and get to as close of a plug n play package setup as possible, please post your pics and list of mods/costs. Especially, if you have done either an LS3/4L80E or LQ9 setup. My 72 C20 is my daily driver, so getting it done and back on the road in as little time as possible is an understatement. Thanks!
'72 C20 Custom Camper, crate 350, T400, Dana 60, ps, a/c
bcwilson_1 is offline   Reply With Quote
Old 02-08-2018, 08:36 PM   #2
thehata1
Re: Complete LS3
Subscribed...
thehata1 is offline   Reply With Quote
Old 02-08-2018, 08:41 PM   #3
A1971Blazer
A1971Blazer's Avatar
Re: Complete LS3
here it is if you have the coin
the mounts and such can be purchased as well as everything else you need
https://www.mygmwholesaleparts.com/o...SABEgJrEPD_BwE
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 02-08-2018, 11:47 PM   #4
bcwilson_1
Re: Complete LS3
That's it, but I need more info on having to upgrade gauges, gear shifter, etc. Things like that as well. And I'd rather stay away from brand new if I can. I was told to check out www.lsx4u.com but unless I missed it, they don't offer the ls3. If I did the lq9, I would probably go through them.
Old 02-09-2018, 08:46 AM   #5
A1971Blazer
Re: Complete LS3
There's a wealth of information on the LSx swap in various threads all through this forum.....but I doubt you'll find one that has every last detail of the swap from start to finish...
One final thought...you could buy a cheap beater to drive while you're engaged in the swap...then sell it afterwards....just a thought...
Anyway...good luck if you decide to pull the trigger on it.....
1967 C10 Step side
1968 C10 Step side
Old 02-09-2018, 11:15 AM   #6
ls1nova71
ls1nova71's Avatar
Re: Complete LS3
.you could buy a cheap beater to drive while you're engaged in the swap...then sell it afterwards.....
The whole time I was reading this thread, this is waht I was thinking, but you beat me to it! To the OP, a swap can be completed fairly quickly with some practice, but it sounds like your first swap, so it will likley take longer than you think. Add to that, if you get in a hurry, you'll be more inclined to cut corners which will probably decrease its reliability in the long run. Read as much as you want, but real world hands on experience will get you further. Not saying to not plan it out, but do expect the unexpected road blocks. I would get most of the parts you are going to need, then dive in, and if you get stuck, ask for some help, there's a lot of guys on here that are willing to give advice. I have 2 builds in my sig, that you can check out, with the rusty truck being probably the most complete.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-09-2018, 10:29 PM   #7
bcwilson_1
Re: Complete LS3
I'm actually looking for a 4x4 right now because I can't even get out of the driveway with the foot of snow we got last night!
Old 02-10-2018, 12:30 AM   #8
cdub2010
Re: Complete LS3
Do a quick once over on craigslist or ebay and see your looking at an easy 10 Thousand dollars for an used ls3 swap. Double or triple that for all new? If your not willing to do the leg work on specing / pricing out a swap how would you even think you could do the actual work. Im not knocking you for a lack of skill or time, might be best to just call some shops and open your checkbook or get that gold card out.
simple google search (ls3 c10 pickup) show a few, one shows roughly $19000 with a list of items and part numbers.
Might be best to buy a truck done with an ls and drive the crap out of it.
cdub2010 is offline   Reply With Quote
Old 02-10-2018, 10:15 AM   #9
A1971Blazer
Re: Complete LS3
I'm sure that if you look around, you can find a shop that will do the swap turn-key...but as mentioned, it will be expensive...I'm doing my own, but it's not my daily driver.....so time isn't a huge concern
right now, I'm all in with 90% of everything I need at around 5K
.... a low miles, 2002 Fbody 5.7, all aluminum true LS1....a fully rebuilt 4L60E.....and NP241C transfer case......Entropy LS swap radiator....reworked harness, efi fuel tank and high pressure pump...
The other 10% is all the little stuff to button it all up...plus my time..!
1967 C10 Step side
1968 C10 Step side
Old 02-10-2018, 05:26 PM   #10
bcwilson_1
Re: Complete LS3
That sounds more like the numbers I want. If I can't go ls3 for that I'll just go basic 5.7 efi. I don't care really that much about what engine as long as it's efi andI can tow my boat at hwy speed for more than 10 mpg!
Old 02-10-2018, 06:46 PM   #11
mongocanfly
mongocanfly's Avatar
Re: Complete LS3
in my 81 ton it had a 150 or so hp 350 sm465 with 4.10s when I got it...barely got 10mpgs empty...I dropped in the lq9 at 345hp put in a nv4500 with the 4.10s and now I get 17mpgs empty...and PLENTY of power...I regularly pull 9500lb gross loaded trailer...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-11-2018, 12:30 AM   #12
bcwilson_1
Re: Complete LS3
So would simply getting an overdrive transmission help a lot with highway speed 60+ with my current setup or would I still need new gears? I was thinking 3.73 or something. I have 3 speed and 4.10.
Old 02-11-2018, 12:34 AM   #13
mongocanfly
Re: Complete LS3
I'd keep the 4.10s and get a od trans....
Mongo...aka Greg
RIP Dad
RIP Jesse
