Old 02-15-2018, 05:20 PM   #1
dirish
dirish's Avatar
Squealing noise when on gas in reverse, now .......
Now no fwd gears. Works in 4x4.
New crate install, new torque converter. 10 miles on it since new converter. 4x4 moves truck , also hubs were not locked in? Any ideas.
dirish is offline   Reply With Quote
Old 02-15-2018, 09:53 PM   #2
SeventyOne
Re: Squealing noise when on gas in reverse, now .......
Wait so when in 4WD (high?) and with the hubs unlocked it drives - so it must be RWD right?
But take it out of 4WD and you have no forward gears...sounds like a Tcase problem to me if 2Hi isnt working but 4Hi gets you moving.
Please confirm the hubs are unlocked so we know you're moving in RWD mode.
SeventyOne is offline   Reply With Quote
Old 02-15-2018, 10:01 PM   #3
dirish
dirish's Avatar
Hubs were unlocked. Worked in 4 lo, 2 hi, didn't try 4 hi.
Hour later back to driving, Not in 4 wd. Steal a awful squeely from somewhere when In reverse with gas applied, nothing at idol in reverse. (When I say driving I mean 5 feet fwd and back) Sounds like converter, but I can't check while it's in reverse. Never ever a issue till pulling motor for a warranty leak repair added torque converter. Rollback home do to weather. Drove about 10 miles. Drove fine.
Old 02-17-2018, 12:13 AM   #4
YoungPup1977
take the bolts out of the Torque converter and see if torque converter turns freely...start engine while TC is disconnected and see if noise goes away...
Sounds like the pump gears are NOT into the TC correctly... I have seen this where the trans works fine but slowly wears down the pump gears...
You can remove the cooler lines, start engine with TC connected.... and see if any pressure lost....make sure you do not spray ATF all over the place....
What kind of trans do you have ? Did you leave trans in vehicle while you replaced the engine ? How did you install the NEW TC into the trans ?
YoungPup1977 is offline   Reply With Quote
Old 02-17-2018, 08:43 AM   #5
dirish
dirish's Avatar
Thanks Guys! Th350.
A mechanic friend is gonna check it out today.
I really want to know the problem before I take it back to shop. I'll keep you posted. Thanks again!!
Old 02-17-2018, 06:51 PM   #6
dirish
dirish's Avatar
Re: UpDATE squealing noise when on gas in reverse, now .......
I'm embarrassed to say..... the transfer case was bumed into nuetral. I put in 2hi as it should be, all is well. PTL
4x4 works, no fwd gear unless 4wd, transmission
