![]() Join Date: Dec 2009
Removing Choke And Throttle knobs 67 cluster
I need to remove the cluster out of my 67. How do I remove the knobs off of the choke and throttle. How do I do that?
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
Roadtrip!
![]() Join Date: Feb 2003
Re: Removing Choke And Throttle knobs 67 cluster
For the choke, pull it out a little bit and hold onto the metal rod with a pliers and unscrew it. For a manual throttle, there will be a little set screw going in sideways like a wiper knob.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Thank you!
#4 | |
![]() Join Date: May 2014
I also thought about disconnecting the choke cable from the carb and pulling it through, but the cable has a little bend on the crab end. I'm troubleshooting my fuel gauge and just want a little peek in. Not wanting to buy a choke cable.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
If you are just wanting to pull the instrument cluster out a little bit,
You can remove the screw in the cable clamp on the carb. That is an aftermarket choke cable. Hope this helps. ![]()
#6 | |
I managed to get my hands in behind and there was a nut on back that I could loosen and get some room to see in.
It is an aftermarket cable. Looks like i could disconnect from the carb end and thread the whole cable assembly out, but I just need a peek in to see if my fuel gauge wires are all intact. Sorry for the sideways pictures.!!
Thank you. Big help.
Why would they want to make them all the same.....
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
