02-20-2018, 02:58 PM | #1 |
Equus 3-3/8 Inch Tachometer
Anyone happen to know if the Equus 3-3/8 Inch Tachometer
Part #: 6088 Line: EQU will work with LS. It has capability to flush mount and can be set to 4 cylinder. My connect and cruise package has a wire to drive a tach. Thanks |
02-20-2018, 11:33 PM | #2 |
meowMEOWmeowMEOW
Re: Equus 3-3/8 Inch Tachometer
It should. Some tach's need a pullup resistor to properly display the readings. I believe there was a thread a long while back with resistor values if needed. I used a resistor on my swap when I originally did it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
