Old 02-20-2018, 08:17 PM   #1
Hubscrub
Cruzin
Hubscrub's Avatar
Are my door hinges bent? 59 apache
I've had problems with my door in the trail fittings since i've replaced the rust in it. The bottom hing mount in the door was broke when i bought it so the door has been abused, hitting the fender etc. I took it off again and noticed the hinges where curved out the same direction that my door wants to stick out. Also i have installed new pins and bushings in the hinge.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 02-20-2018, 08:33 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Are my door hinges bent? 59 apache
what do the pass side hinges look like?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-20-2018, 08:35 PM   #3
dsraven
looking at the pics I would say yes, unless the pics are distorted somehow. mine were straight where they bolt to the door. you got nuthin to lose from heating them up and getting that part straight.
Old 02-20-2018, 08:48 PM   #4
MARTINSR
MARTINSR's Avatar
Just remember, it takes a LOT to bend a hinge, the door is going to bend WAY before that hinge bends. So what is off, I can't tell you. But I would be looking at the pin in the hinge way before it being bent. And I would be looking at where that hinge bolts being bent before anything!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is online now   Reply With Quote
Old 02-20-2018, 08:52 PM   #5
dsraven
great point martinsr, but it does look like the "bolt on" part of the hinge is not flat/straight. maybe a shadow thing or a distortion on the pic thing?
the lower hinge mount inside the door is a usual rusted out area on these trucks. may be a good place to check as well.
Old 02-20-2018, 08:56 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
I haven't removed the pass. door yet. Its also against the wall so i've have to move alot to get it.
Brian
Yes, i agree the door "front" forward facing area was pulled out like a bow away from the door i used a mallet and got it in some and it did help but haven't got the whole picture yet. I have alot to learn with body work. Thanks
Proverbs 3:5,6
Old 02-20-2018, 09:57 PM   #7
Foot Stomper
Foot Stomper's Avatar
I'd bet the A pillar is "tweaked" after ruling out pins and bushings. No way the hinges are bent unless there was a collision of gigantic proportions!
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 02-20-2018, 10:45 PM   #8
BIGglaSS
BIGglaSS's Avatar
I just looked at a set on my workbench, and they are flat on the side that mounts to the door.
BIGglaSS is offline   Reply With Quote
Old 02-20-2018, 11:06 PM   #9
Softpatch
Softpatch's Avatar
can't say put a straight edge on em
...Pic could be distorded
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 02-21-2018, 02:15 PM   #10
_Ogre
_Ogre's Avatar
door hitting fender is typical indication of bad front cab mounts causing the front of the cab to sag down
if you ever see pliers bent front door edge (cringe) it is for this reason
motor oil soaked after 60 years tends to soften rubber
rusted lower fender mount will also cause the fender bottom to ''relax''
another cause for front cab sag is removal of the trans x-member to install an automatic trans
that trans x-member also supports the front cab supports
shop air compressor timer
Old 02-21-2018, 02:18 PM   #11
_Ogre
_Ogre's Avatar
try a block of wood and a floor jack under the front cab mount, jack up a little to see if the door clearance improves
ogre has never tried this method, just a suggestion for checking
Old 02-21-2018, 06:39 PM   #12
Hubscrub
Cruzin
Hubscrub's Avatar
Thanks for all the replies they are definitely curved out not straight. I was thinking they should be, but not sure, so I asked. I will work on that and come back with my results.
Proverbs 3:5,6
Old 02-22-2018, 01:21 AM   #13
MARTINSR
MARTINSR's Avatar
I think those hinges have a hole at the very back that may not be used as they were in the passenger car. Moving the very back of that hinge is very powerful. If you need to move the front of the door in and out, that is the magic point!
Brian
1948 Chevy pickup
