OE LED Jeep Wrangler Headlights?
Have you considered installing a 2017-2018 factory OE LED headlight (bottom image in this post) from a Jeep Wrangler?
An observer might mistake these modern technology LED headlights as traditional headlights. They might look good on a classic vehicle providing a conservative look with improved modern lighting technology without detracting from the look of a classic vehicle. Most aftermaket LED headlights designed for Jeeps are blacked out or have projecotor lenses that dont quite look right on classic vehicles. These LED headlights can be purchased for $200 per unit, used, on ebay so for $400 you could potentially upgrade to modern lighting and keep the classic look. I've already replaced my headlights with H4 Hella sealed beam conversion headlights (1st and 4th images) but below is my attempt at seeing what OE Wrangler headlights (2nd and 4th images) might look like What are your thoughts on putting Jeep Headlights on a classic ?
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 02-26-2018 at 07:13 AM. Reason: Corrected Headlights description from HID to LED. |
![]() Join Date: Jun 2014
Re: OE HID Jeep Wrangler Headlights?
IMO, the Hella H4 conversion housings with an LED H4 bulb in them is the best bang for your buck to maintain the classic look and have bright headlights.
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
I agree. Honestly, for only $70, I could not ask for the Hella H4 sealed beam conversion to perform any better. The beam pattern is wide witwithout noticable hot spots. It has a sharp cut off and like HID projectors headlights.
Still though, it would be nice to have modern LED headlight technology without the trendy look. I'll stick with the Hellas for a while.
Photo Gallery of 1972 K/5 Blazer CST |
Can you link to the Hella lights you use? Are you running the upgraded wiring harness with relays?
I purchased the Hella headlights (002395801) and wire harness with relays upgrade from Amazon. I have not installed the harness yet but will when the weather warms up.
https://www.amazon.com/gp/aw/d/B001G...?ie=UTF8&psc=1 https://www.amazon.com/gp/aw/d/B06XH...?ie=UTF8&psc=1
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 02-26-2018 at 06:13 PM. |
thanks for posting. Wow the painless relay kit is $190. That's quite the price variance...
https://buypainless.com/products/30815? |
Ouch! $190? Not so painless on the wallet.
$22.50 is much easier to swallow.
#8 | |
I installed it yesterday afternoon and it was plug and play- no cutting, no crimping and no soldering. The universal harness with relays was exactly the right length as if it was designed specifically for a 72 Blazer. The ceramic female connectors for plugging into the headlights was a nice surprise upgrade over my expectation of original plastic style connectors. This will help prevent the harness from deforming due to heat. The wire harness was easy to hide allowing me to maintain a stock engine bay appearance. The H4 conversion headlights stay nice and bright, even at idle. A drastic improvement over the Sylvania Silverstar that I had to keep replacing frequently. The $92 spent on this harness and Hella H4 conversation was worth every penny.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 04-22-2018 at 11:42 PM. |
Be glad you're not building a truck in Canada. Here's the prices we have to pay plus 13% sales tax. Can anyone get me a green card? LOL
https://www.tdotperformance.ca/catal...LLA+002395801+ |
![]() Join Date: Mar 2004
I like the look of them. As long as they don't have color changing halo rings and stuff like that!!! haha
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
I also saw someone linking to this harness for the relay upgrade:
http://www.madelectrical.com/catalog/rly-1.shtml |
Good information, this is on my to do list, thank you all for posting up the links. I like the looks of the H4 sealed beams the best.
Question... Are the h4 bulbs just as bright as the HID set up? My night vision has progressively gotten worse in the last couple of years, so I'm looking for the best option where I can see and not blind oncoming traffic. Just curious for your opinions, thank you.
#13 | |
#14 | |
Have a good week!
#15 | |
As nice as the stock Jeep headlights, the Hella housing with an H4 LED is a great upgrade while maintaining a stock appearance during the day. 1st photo is with high beam. 2nd photo is with low beam. 3rd photo shows beam pattern on the garage door with sharp cutoff. (The last photo is prior to changing the out the dash lights with Yorkim white LED 194 bulbs.)
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 07-25-2019 at 11:07 AM. |
#16 |
I'm with you... my vision certainly isn't getting any better.
The Hella H4 setup is a significant improvement to the Sylvania Silverstar sealed beam (6024) that I had previously, IMO. Hella is not US DOT approved and I've read that this is because headlights are designed for European (left hand drive vehicles/right side of the road like US) with a sharp cutoff. Further down road lighting is almost non existent so it's imperative that you aim these headlights properly and use you high beams whenever oncoming drivers are not visible. The color and performace is not as bright white as HID or LED headlights but much still whiter and brighter than standard halogen sealed beam headlights. Overall, I am impressed with the performance if the Hellas, especially for the price.
#17 |
Interesting upgrade. Great idea.
#18 | |
#19 |
Curious.. do you still get the sharp cutoff with the LED low beams, like that of a halogen in this housing?
#20 |
Yep, the bulbs have LEDs on all sides just like a halogen, wont be perfect like the halogen but its 10X brighter
#21 |
My conversion cost less than $100:
Projector housings with halos (your choice of color) $35 H4 LED’s $35 Custom LED circuits to make the halos into DRL/turn signals FREE (Xmas present) Done. All on Amazon.
'72 K5, known as 'the Fox.' |
#22 |
The LED light quality is very different. I’ve had Halogens and HID’s. We all know what Halogens are like, and HID is better, but the LED light seems to illuminate better and doesn’t so much shine as it glows. It’s almost as if things light up with their own light and reflections aren’t nearly as harsh. I find it easier on my aging eyes to see more. To me, it’s akin to how things can be easier to see under bright moonlight than a powerful flashlight.
#23 |
#24 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Nice upgrade. Are the instrument cluster LEDs able to be dimmed?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#25 |
The LEDs are from Yorkim and run about $10 for 10 bulbs.
https://www.amazon.com/Yorkim-Genera.../dp/B00JRE38EA The LEDs in the dash will dim but will shut off when attempting to dim them really low. There are still two incandescent light bulbs controlled on circuit by the dimmer switch (gear selector on tilt wheel and 2. bulb in 12V source (cigar lighter) so that additional resistance load may have an impact but I can't say for certain. To help answer your question, here is a video of my LED dash lights being dimmed. https://photos.app.goo.gl/GwhNJsoS7zn11twW8 Hope this helps.
