Old 03-03-2018, 01:36 AM   #1
Nuckingfuts
Will 275 Tires Fit in Rear of Fleetside?
This is a direct question which I have yet to find and answer to in all the tire/rim threads on this site (my eyes are bleeding from reading!).
Will a 275/60/15 tire fit inside the rear wheel well of a 1973 fleetside shortbox? Tires will be mounted to 15x8 rally wheels (4" back spacing).
Nuckingfuts is offline   Reply With Quote
Old 03-03-2018, 01:44 AM   #2
85 Money Pit
85 Money Pit's Avatar
Re: Will 275 Tires Fit in Rear of Fleetside?
Yes, they should depending on your offset because I have a set of 295/50 15R on my 15x10 rallies.
85 Money Pit is offline   Reply With Quote
Old 03-03-2018, 01:49 AM   #3
Nuckingfuts
You have a fleetside?
Old 03-03-2018, 02:42 AM   #4
TrailerTrash
TrailerTrash's Avatar
I had 275/60s on stock 15x7 rallies on my fleetside with no trouble. there wasn't tons of room but there was nothing to worry about
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 03-03-2018, 06:26 AM   #5
85 Money Pit
Yes, I do....
Old 03-03-2018, 08:50 AM   #6
sweetk30
sweetk30's Avatar
thats a 28" tall tire
i have a 85 fleetside short bed lowered 2.5" all 4 corners . stock 88-98 ss truck rims now and roller tires i clear 31x10.50x15 mud tires . my truck has a 3 leaf rear spring setup so its not to tall in the rear like some with 4 or 5 leaf .
just whats on it when i got it . using them for rollers till ready for drive time then going the 275/60/15 size . i already have 1 bfg radial ta in this mounted on a 15x8 pickup ralley wheel and tested no problems.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-03-2018, 11:49 AM   #7
Nuckingfuts
I failed to mention that the truck is lowered (5/7) but it shouldn't matter as long as the width clears the wells.
Old 03-03-2018, 02:55 PM   #8
Malo83
Cruzzzn' Vet
Malo83's Avatar
Lot of room, have the same setup on the back.
Malo83 is offline   Reply With Quote
Old 03-03-2018, 01:57 PM   #9
68longhorn
68longhorn's Avatar
I have 275/60r15 tires on 8inch rallys on a 3 inch lowered fleetside. Tons of room in the back. Front may rub if I lower more
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 03-03-2018, 02:17 PM   #10
3drburb
Wow! I haven't been on here for a while now.
Here you go. 275 60 15 on 15x8 with room on both sides to put my fingers, but I don't remember the wheel backspace.
I hope this helps.
3drburb is offline   Reply With Quote
Old 03-03-2018, 02:52 PM   #11
layinrocker65
layinrocker65's Avatar
I have a 4/6 drop on my fleetside and 275s. Plenty of room
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 03-04-2018, 10:49 AM   #12
BLP86
Lowered 7in no issues 275 60 15 8in rally's
BLP86 is offline   Reply With Quote
Old 03-04-2018, 11:10 AM   #13
85/Silverado
85/Silverado's Avatar
I'm running these on my Fleetside and I couldn't go any wider. 0 spacing.
Front Wheels Ridler Style 695 Grey Wheel with Machined Lip (17x8"/5x127mm)
Rear Wheels Ridler Style 695 Grey Wheel with Machined Lip (18x9.5"/5x127mm)
215/55R17 = 26.3x8.5R17
235/50R18 = 27.3x9.3R18
I know yours are higher but these are almost 11" wide at the side walls.
85/Silverado is offline   Reply With Quote
Old 03-04-2018, 11:36 AM   #14
Nuckingfuts
Nice!
Old 03-05-2018, 09:46 AM   #15
blazer2007
looks close but will it fit on a bagged truck with 8 in 0r 10 inch truck rallys ?
blazer2007 is offline   Reply With Quote
Old 03-05-2018, 10:51 AM   #16
SCOTI
SCOTI's Avatar
There's 5 diff trucks pictured in this thread. What looks close?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-05-2018, 10:56 AM   #17
SCOTI
SCOTI's Avatar
Yes. 275's will fit w/room to spare.
295/40-20's on a 10" wheel......
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-05-2018, 11:14 AM   #18
ultrahd4me
ultrahd4me's Avatar
Just as SCOTI and others have said, no problems with a 275. Here's a 285/50 on one my trucks with 1" of room at least.
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 03-05-2018, 08:04 PM   #19
blazer2007
Malo 83 looks borderline
Old 03-05-2018, 09:16 PM   #20
75C10
I have a 4 / 6 drop (flip kit) and 295 -45 /20 on the rear with 20X10 wheels with 5" BS.The tires are very close to the wheel well lips (less than little finger) and I built an aluminium angle device to prevent the sharp edges from cutting the tires. I have yet to rub as best I can tell. No marks on the tires. Been this way for 10+ years. Rear end is reasonably centred but not perfect.
Works for me.
75C10 is offline   Reply With Quote
Old 03-06-2018, 02:17 AM   #21
Malo83
Cruzzzn' Vet
Malo83's Avatar
They'll tuck whenever I carry a load that's heavy with no problems.
Old 03-06-2018, 07:47 PM   #22
blazer2007
what size are you running on the front?
Old 03-09-2018, 10:46 PM   #23
bbbc10
Diggin The SquareLife
I had 275/60 on a 15x10 rally lowered 6" with no problems
bbbc10 is offline   Reply With Quote
