Old 03-03-2018, 10:19 PM   #1
todds66
1968 manual transmission
I have a stock 4 speed manual transmission and was hoping someone could tell me which 4 or 5 speed would be the best and easiest to swap with this one. We have an inline 6 cylinder 292 motor.
1966 Custom Cab SWB SBW Fleetside
1968 C10 BBW SWB Fleetside
todds66 is offline   Reply With Quote
Old 03-03-2018, 10:48 PM   #2
kwmech
Re: 1968 manual transmission
With the 6 cyl I'd go with the NV3500
Old 03-03-2018, 11:29 PM   #3
todds66
Thanks. I will research them now
Old 03-04-2018, 02:02 AM   #4
HO455
HO455's Avatar
Here is a link to Novak's web site. Click in the manual tranny section to compare tranny's.
https://www.novak-adapt.com/knowledg...ssions/manual/
RIP Bob Parks.
Old 03-04-2018, 08:43 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
This thread covers just about everything....
http://67-72chevytrucks.com/vboard/s...d.php?t=438224
LockDoc
Leon
Old 03-04-2018, 09:25 PM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Stock vintage set up w/ 292 L6 would be SM465. M-Y '68 was first year for 465. That's the granny gear-2-3-4 four-on-the-floor, cast iron case. Ultra reliable and bombproof.
Old 03-04-2018, 11:17 PM   #7
todds66
68OrangeSunshine, yes it has a granny 1st gear, 2,3,4. We are looking for something more efficient to put in.
Old 03-10-2018, 09:48 PM   #8
'68OrangeSunshine
If I could get one I'd use the New Process A833 [RPO MY6 or MM7 - 4x4]. Originally a Mopar beefy 4-speed [like the SM465] in cast iron, it got reworked with the granny gear eliminated, and 2-3-4 became 1-2-3 and 4th became a 0.73 OD, all in an aluminum case. Not rated for high horsepower or heavy torque applications.
Chevy used them in the '80s, ending with the '87 MY in trucks and Blazers. There's an 11 page thread about the NP A833:
http://www.67-72chevytrucks.com/vboa...d.php?t=670789
Old 03-11-2018, 10:37 PM   #9
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
Look into the AX15 5 speed trans also. Novak makes an adapter to put them behind a standard GM pattern bellhousing. I am installing the newer version of the AX15, called the AR5 in my '67 GMC with a V6. Novak's adapter works on that trans also! Sourced the trans from a 2009 Colorado 4 banger truck. The Jeep guys beat the snot out of these transmissions and have few issues!
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 03-12-2018, 10:28 AM   #10
LockDoc
LockDoc's Avatar
Mike
The Jeep AX15 or the Toyota Supra Turbo R154 5 speeds.(basically the same trans) The adapter is a little pricey but it is milled, and the kit comes with a GM front bearing retainer/throwout sleeve and mounting hardware. I have the AX15 in my '34 Ford Coupe behind a Chevy 377 stroker motor. I haven't driven it much yet but it seems pretty smooth.
LockDoc
Leon
Old 03-12-2018, 11:58 AM   #11
schwoch1
schwoch1's Avatar
LockDoc
Yep, adapter was $320 shipped to me. I was able to get the transmission for $150. in the end after a can of paint for the transmission I got about $500 into it. The only pisser is the newer Colorado transmission has a 26 spline input, and no one makes a 12" clutch in that size. In my application an 11" clutch will be just fine for me.
Mike
