Old 03-12-2018, 06:33 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Help with adding FiTech EFI.
So I called them up and they were speaking a foreign language. Current setup is a 305 with a Rochester Quadrajet. Research says that that is a 4-barrel carb. This is new to me for carb. So they mentioned part number 30003. I will need a 4 barrel intake manifold which is on there already. Which thing they start going into details about a high pressure fuel pump. Then they asked me if I have a mechanical or electronic fuel pump. I don't know. In the future I want to add an under the bed fuel tank. Then they start going into surge tanks and fuel Regulators. Now I'm just all confused. Then the guy says about buying an inline pump. For right now I just want to get the truck running and upgrade the fuel pump to i guess an electronic fuel pump. And then add under the bed tank in the future as an upgrade. So I added a couple pictures of the engine setup. Maybe someone can tell me what my engine is all about.
desert-rat is offline   Reply With Quote
Old 03-12-2018, 06:37 PM   #2
desert-rat
Re: Help with adding FiTech EFI.
Oh yeah. The 305 is not the stock motor. The engine casting number is for 460776.
Old 03-12-2018, 07:19 PM   #3
chiefcfd
chiefcfd's Avatar
That is correct, you will need an electric fuel pump. You will also need a return line to the fuel tank. It would be easier to relocate the tank at the same time. The rear tanks usually have the ability to accept the return line. I don't know about FiTech but the Holley units are available as a kit with the correct fuel pump and lines.
https://www.holley.com/brands/holley...h_fuel_system/
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 03-12-2018, 08:13 PM   #4
Bigdav160
Bigdav160's Avatar
Your current low pressure mechanical pump is located at the middle bottom of your first pic.
While it could supply enough fuel it can't do the high pressure needed for the fuel injection.
What would be cool is if someone would build a retrofit mechanical high pressure fuel pump. It sure would simplify redesigning your fuel system around an electric pump
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-12-2018, 08:41 PM   #5
harpo231
harpo231's Avatar
Summit has this ....
Quick Fuel 30-350-1QFT
Mechanical Fuel Pump Small Block Chevy
Part Number: 793-30-350-1QFT
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-12-2018, 11:28 PM   #6
desert-rat
Thanks all for the replies. Looks like the Holley setup may take care of what im looking for. Seems to be a whole kit.
Old 03-13-2018, 06:35 AM   #7
FRCvette
I used this. No return line to tank needed. Costly but worked great.
http://www.jegs.com/images/photos/300/350/350-3605.jpg
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 03-13-2018, 11:11 AM   #8
AK49Watson
Going to play devil's advocate here, not trying to be rude... But if you don't have a firm grasp on even the carbureted basics... Fuel injection is going to give you a hard time. Even those self tuning units... Aren't completely.
1970 GMC C2500, Vortec 406SBC, TH350
AK49Watson is offline   Reply With Quote
Old 03-13-2018, 01:18 PM   #9
clay68c10
clay68c10's Avatar
Yes, this is true.
Get it running ok with the 305 and Q-jet. Tackling an EFI install isn't a novice task. That's a lot of money to spend on an engine that sounds like an unknown, non-runner.
You can have that 305 up and running as-is for a lot less, maybe $100.
Then figure out what you want under the hood, and spend the money when you have a plan.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-13-2018, 03:35 PM   #10
TeamEstep
TeamEstep's Avatar
Fitech makes a "command center" which is a self contained tank and high pressure fuel pump that is fed from your mechanical pump.
TeamEstep is offline   Reply With Quote
Old 03-13-2018, 11:12 AM   #11
harpo231
harpo231's Avatar
I'm using pro-flo3 ... comes w/intake....
Stan
67 swb BLU MULE
