6.2 fuel sending unit problems
I'm changing the sending unit on my 6.2 and can't find one like it it has 3 outlets and one plug for the gauge and a exterior ground and two of the outlets go into the tank are long and one is short I can't find another like it anywhere it is a old military truck so who knows what it's from and when I look at the one it recommends it has two plugs and the ground is internal please help thanks
Posted via Mobile Device |
Re: 6.2 fuel sending unit problems
Try a Spectra FG05K for driver side or FG05L for pass side.
For surplus try Hillbilly Wizard or Ted's Trucks & Stuff. These are for M1008 but may be the same for M1009. |
When you say two plugs that's electrical plugs correct?
Will your wiring harness plug into one of the plugs or do the wires need to be "Divided" between the plugs? You have an M1008 or M1009 or is your tank just from a CUCV? |
post up some pics of what ya got . see if I can match it.
I have 2 tanks with senders from a diesel truck I parted . looked up for 1985 k30 6.2 diesel . verified 1984 - 1985 - 1986 the vintage of almost all military trucks of this style take the same sender listed . unless military did a weird custom thing . driver side 3 port https://www.rockauto.com/en/moreinfo...053065&jsn=459 pass side 3 port https://www.rockauto.com/en/moreinfo...053065&jsn=458 these what you looking for ? 1 plug/pin is sender feed . the other is water in fuel ? if I recall. short is tank vent / 5/16 is return line / 3/8 is fuel supply . ground is flat spade on 1 of the lock tabs in the pic .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. Last edited by sweetk30; 03-13-2018 at 05:48 PM. |
Moderator
![]() Join Date: Oct 2008
How old is the fuel filter?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
My dad had been using this truck as his everyday driver for a year and it has new fuel in it now we replaced the tank and sending unit and fuel filter and nothing has changed plus the fuel pump is new
Moderator
Is it surging when the power drops off?
No it's just dies no jumping or nothing like that
Anyone have any ideas it's still losing power and it seems to be worse when it's hot
check fuel return lines. blow through from injection pump outlet with air back to tank. also check to see if the fuel return fitting in the top of the injection pump is clogging up. there's a glass check ball inside that fitting that can trap junk in there
back pressure on the fuel return is actually what kills a 6.2 truck when you shut them off. seen the return hose and that outlet fitting plugged more than once in my fleet of trucks.
I found this in my CUCV manuals.
GM part # for Fuel, Tank Meter on M1008 is 25004137. For the M1009 it is 25004140. The units are different between the M1008 & M1009 |
#15 |
Moderator
The M1009 is a Blazer chassis with the tank between the frame rails.
M1008 M1010 M1028 & M1030, I think I got em all, are pickups with saddle tanks.
#16 |
By looking at the illustrations, the M1009s have four outlets & M1008s have three. The center outlet on the M1008 hooks to a short piece of tubing that drops over to inside the frame & has a cap on it. They list this assy as a "Tank Drain".
I spose you are to hook a pump onto this & suck the tank out. I'll look in my TMs for the procedure. But in the short run it looks like a feature not needed for our purposes. |
#17 |
Moderator
You really only need vent, supply, and return for the diesels. The tank drain is superfluous.
GM stopped installing the tank drain in the Civvy rigs around 1984 or 1985 or so. Since the military spec for the trucks was based on an early 1984 chassis, and the military gets nervous about changes, they kept building them exactly the same til Uncle Sam stopped ordering them. If it's stock pre mid-84 you'll find a valve somewhere around the spring hanger on the frame. It may actually be inside the spring hanger. The TM will probably tell you. You can get rid of this drain line unless you're going for exactly original.
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-15-2018 at 02:33 PM. |
#18 | |
#19 |
Moderator
superfluous
[soo-pur-floo-uh s] adjective 1. being more than is sufficient or required; excessive. 2. unnecessary or needless. 3. Obsolete. possessing or spending more than enough or necessary; extravagant. Ahh tends ta use them thar big words sometaahms. ![]() ![]() ![]() ![]() ![]() ![]()
#20 |
This forum is FULL of $10 words today!
