03-13-2018, 02:47 PM | #1 |
Truck wonders
Morning all, well my question is what do I need to add rack and pinion to my truck. I did a LS 6.0 swap in my truck and want it to be more user friendly when I drive. I replaced all the suspension back to factory new. But the truck still wonders and has bump steer when I let off the gas. Thanks
03-13-2018, 03:09 PM | #2 | |
The Older Generation
Re: Truck wonders
Your problem might be because your center link is installed backwards. The nuts on the joints should be facing forward. That changes everything.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-13-2018 at 03:14 PM. |
03-13-2018, 03:41 PM | #3 |
Re: Truck wonders
See above
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
03-13-2018, 04:22 PM | #4 |
Re: Truck wonders
I am in the midst of a bolt in install from Flaming River. I will update you on any difference in driveability. Also, I can’t speak to fitment with an LS. I am installing with a 250 L6 and will require a roughly 1/2 in motor mount lift.
Kevin |
03-13-2018, 04:28 PM | #5 |
Re: Truck wonders
Not understanding what you mean....
He said his truck "still wanders and has bump steer when I let off the gas" and I said the problem might be because his center link is installed backwards, which it is, and which could cause the problems he is seeing. He may not need to go to the trouble and expense of installing a rack if correcting that regains his "driver friendliness" Cryptic posts don't add anything to the thread. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-13-2018 at 04:37 PM. |
03-13-2018, 05:12 PM | #6 | |
Re: Truck wonders
Is that better? LOL!
03-13-2018, 05:28 PM | #7 |
Re: Truck wonders
It's a wOnder the truck doesn't wAnder with that thang thataway.
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
03-13-2018, 05:38 PM | #8 |
Re: Truck wonders
see above = what Doc said or x2
Stan 67 swb BLU MULE posted via flip-fone |
03-13-2018, 06:57 PM | #9 |
Re: Truck wonders
03-13-2018, 07:42 PM | #10 |
Re: Truck wonders
First off thanks for all the helpful replies. I just came from my new mechanic who's going to switch it around for me we'll see if that solves the problem.
Take a sec to enjoy how far I've come from when I first got this suspension redone on this truck true craftsmanship |
03-13-2018, 08:23 PM | #11 |
Re: Truck wonders
Yup, don't see that everyday. Reminds me of the Burban I looked at buying that had the springs removed to lower it.
Good job on cleaning that mess up.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-13-2018, 09:07 PM | #12 | |
Re: Truck wonders
LockDoc
03-13-2018, 05:45 PM | #13 |
Re: Truck wonders
Flip that center link and save a few bucks! With everything new it should drive pretty well.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
03-13-2018, 10:14 PM | #14 |
Re: Truck wonders
Ok well ****, now I just realized my centerlink is on backwards. More work for me. Yay.
03-14-2018, 11:34 AM | #15 |
Re: Truck wonders
Any advice on removing the pitman arm and idler arm from the centerlink without ruining my brand new parts and dust boots?
03-14-2018, 11:39 AM | #16 |
Re: Truck wonders
Use the right tools. Pickle fork or ball joint remover. They're brand new, shouldn't be hard to remove.
1970 GMC C2500, Vortec 406SBC, TH350
03-14-2018, 12:49 PM | #17 | |
Re: Truck wonders
Or, use the pickle fork as a pry bar while using the air chisel on the tie rod arm. Try to not let the pickle fork contact the rubber with this method. Lastly you could put force pulling the tapered joint(tie rod, Idler, pitman) while hitting the side of the female taper with a large hammer. |
03-14-2018, 01:12 PM | #18 |
Moderator
Re: Truck wonders
You need a puller for the pitman arm. Local autozone loans the tool for free. You can also buy it at harbor freight for about $8. Smack the side of the centerlink with a sledgehammer to remove the idler arm, it should pop right out since it’s new. I use a pickle fork on old stuff that’s coming out to be replaced, where damage to the rubber boot doesn’t matter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-14-2018, 01:30 PM | #19 |
Re: Truck wonders
Ok cool. I have a pitman puller, but wasn't planning to pull the pitman arm off the gearbox.
Was thinking: Unscrew each tierod connector, leave the tie rods on the centerlink. Then remove the centerlink from the idler and pitman (tapered side). Then flip it 180. That'd put the tierod bolts frontwards. I can prob make a brass rod to fit into my air chisel. Since they're new, make just smacking the centerlink with a dead blow hammer would free it? IDK, just don't wanna ruin $100 worth of new Moog parts. |
03-14-2018, 04:39 PM | #20 |
Re: Truck wonders
Hitting it will knock the tapered joint loose but hitting it without pressure pulling it outwards will probably not do anything. They also make a screw type tie rod puller which may fit the idler and pitman arm, I'm just not sure of the fit, they usually don't fit well. If you can borrow one at oreillys or autozone it would be worth a try.
I suspect you have a recent alignment....you could save that alignment by measuring the toe in before you change the parts out and then adjusting to the same spec after the switch. To replicate the toe in, roll the tires over 2 layers of plastic sheeting, thick black garbage bag pieces(reduces friction of tire on the ground), wire a board across each tire through the wheels, measure the distance front and rear of the tire using the boards, subtract front from rear distance to get current toe in. Adjust each side equally to replicate this distance once you switch the parts out. |
03-14-2018, 06:19 PM | #21 |
Re: Truck wonders
Hasn't been aligned yet, still assembling it.
03-16-2018, 10:35 AM | #22 |
Re: Truck wonders
So after some more looking around we found this too
03-16-2018, 12:33 PM | #23 |
Re: Truck wonders
Ooops! That doesn't look good.
LockDoc
03-16-2018, 12:42 PM | #24 |
Re: Truck wonders
subscribed, wanna see how this turns out!
03-16-2018, 11:43 AM | #25 |
Re: Truck wonders
Wait, are the A-Arms connected to the frame with U bolts?
-Paul |
