03-16-2018, 08:01 PM | #1 |
Looking for some power steering insight.
A PO installed power steering on my 67 Burban and I have no information on what parts they used to make it happen. The steering works fine but I'm looking ahead for when it will need some help. It's the bracket that hold the pump to the block that is annoying me. It is hard to see in the photo but the circled bolt goes through the bracket and the motor mount's forward hole and holds both in place. There is no way to remove the bolt without removing the center motor mount bolt and jacking the engine up. And of course to get the center mount bolt out I had to remove the header. There is very little room to get wrench on the bolt. And if you did get it loose the high pressure power steering hose is right there in the same space preventing the bolt from being able to come out enough. I don't know if the hose is routed wrong or the hose itself is wrong, or do I need a different mount for the pump? There are three bolts holding the bracket to the block. The red arrows point to the other two which are easy to access.
Thank you in advance for reading and any feedback.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-17-2018, 01:28 AM | #2 |
Re: Looking for some power steering insight.
My bracket looks just like yours.Yes they are a pain for that motor mount bolt.I believe that is the way they came.Someone else with more knowlege than me hopefully will chime in.
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
03-17-2018, 09:18 AM | #3 |
i have the same i bet that is the stock set-up Ive done my conversions while motor is out its a PIA...
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-17-2018, 09:49 AM | #4 |
It works fine? I would sleep well and "worry" about it IF it ever fails, which isnt likely to happen.
03-17-2018, 11:14 AM | #5 |
Here's a better look at that bracket and it has a 3rd bolt in the bottom that when removed separates the 2 sides so you don't have to mess with the side attached to the engine mount .
03-17-2018, 02:41 PM | #6 |
Thanks everyone for the information. The track record of the PO on the truck has lead me to question things I find. So it's a PITA from GM and that's what it is. Since the engine is coming out I thought I should ask if there was a better way to mount the pump now would be the time to correct it. I will be cleaning up the unit and will make sure the bolt that holds the two brackets together is serviceable. That's an awfully nice bracket you have there Grumpy. SHINY!!!!!! Thanks for sharing.
03-17-2018, 04:36 PM | #7 |
Shiny makes them go faster doesn't it ? The problem is now all the rest of the factory brackets are at the chrome shop because heaven forbid they all don't match ...Call it a sickness this stuff never ends ...
03-17-2018, 06:02 PM | #8 |
Strongman Garage
I added power steering of the same style to my Suburban and that bolt is a major PITA
Just what it is
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
