Old 03-18-2018, 07:47 PM   #1
Jeff's72C10*
Active Member
Jeff's72C10*'s Avatar
RPO code ??
I purchased a 72 Custom 10 deluxe a while back. I believe I'm the 4th owner. Somewhere along the line, the factory glove box door was swapped out with a chrome one. Thus eliminating the decal on the door listing the paint and options. Anyway to get this info using the VIN? Any help would be appreciated, thx.
Jeff's72C10* is offline   Reply With Quote
Old 03-18-2018, 07:51 PM   #2
harpo231
harpo231's Avatar
Re: RPO code ??
Yer outta luck pal ....Unless built in Canada...
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-18-2018, 08:12 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
Re: RPO code ??
You might be able to find a build sheet under the seat in the springs or stuffed around the gas tank somewhere. That’s about your only hope unless it was built in Canada as said above.
Tyler
Old 03-18-2018, 08:18 PM   #4
Jeff's72C10*
Active Member
Re: RPO code ??
Kind of had that feeling it was a lost cause. The gas tank was swapped out also from what I was told by the previous owner so that option is nill. I will check under the seats though. Thanks for the info, appreciate it.
Old 03-18-2018, 08:40 PM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: RPO code ??
I found a fragmentary Build Sheet in the passenger door, when I was working on it. I put the jigsaw pieces in an envelope. Since lost it. Someone thought they were being 'helpful' by cleaning out my desk.
Old 03-18-2018, 09:49 PM   #6
jocko
jocko's Avatar
Re: RPO code ??
I found TWO build sheets under my springs, one for my truck and one for the guy's truck that is still lookin for his build sheet! Probably before or after on the assembly line. Who knows.
