Old 03-22-2018, 06:19 PM   #1
bubbasimms
Looking for exhaust manifold for a 250 with a fresh rebuild
I have a couple OEM exhaust manifold, both with issues. Both have exhaust flapper issues and a broken stud or two...plus they are 50 years old and crusty. So I was looking at the replacement manifold from Summit, ATP part #101140. For 145 bucks I was wondering if it's any good. Anyone using one of these? https://www.summitracing.com/parts/atp-101140
bubbasimms is offline   Reply With Quote
Old 03-22-2018, 06:33 PM   #2
harpo231
harpo231's Avatar
Re: Looking for exhaust manifold for a 250 with a fresh rebuild
From ATP...
Manufactured to OE design ensuring manifold will line up and flow like the original unit
High grade metallurgy resists fatigue cracking and breakage
Precision machine finished providing smooth installation and leak free performance
Upper and lower flange gaskets along with lower flange hardware are included (Heat shields and plugs are included where needed)
Industry Leading Limited Lifetime Warranty
The casting could be from any number of countries ,but if it was machined right , it should be fine ....
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-22-2018, 06:36 PM   #3
bubbasimms
I read all that. I also read some reviews that said the bolt holes weren't perfect and some said they were great. I can do a little massaging on it if need be, but I was looking for words of wisdom from the experienced here on the forum.
Old 03-22-2018, 06:41 PM   #4
harpo231
harpo231's Avatar
They will come , trust me ....
Stan
67 swb BLU MULE
Old 03-22-2018, 11:12 PM   #5
CST10
CST10's Avatar
If you buy it, let us know how it works out. I’m interested in one myself.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 03-22-2018, 11:22 PM   #6
Jason Banks
Jason Banks's Avatar
I bought an ATP one from Amazon that was a 'Warehouse Deal' that was listed as " Used - Like New - Item will come in original packaging. Packaging may be damaged. " and paid $50.41 back in August 2015. At the time there were several available.
Put it on last spring. and it's perfect. Kind of wish I had bought all they had.
My old manifold needed the bushing in the shaft for the flapper replaced and had one of the bolt flanges broken off. I still have 2 other original manifolds but decided the ATP was the way to go. It's mounting surfaces are flat and I cleaned up the inside with a carbide rotary file because the casting was very rough inside. I wouldn't say I ported it...but maybe I did...because I took a bunch of material out of the inside.
edit: once I got it on an running...I discovered there was a threaded hole around the 2nd cylinder that needed to be plugged because I had a leak there. My old manifold had a 1/4-20 bolt in a similar hole so I transferred it over and all was good.
edit again: Yes the gasket that it came with was banged up ...but I didn't plan on using it anyway, because I had a Fel Pro out of a gasket kit. I found the hardware that came with it acceptable.
Jason Banks is offline   Reply With Quote
Old 03-23-2018, 12:01 AM   #7
bubbasimms
Outstanding review Mr. Banks. Thanks for taking the time to write that up. Sounds like I just spent another $150.👍
Old 03-23-2018, 07:19 AM   #8
Grumpy old man
Grumpy old man's Avatar
Or you could just spend $40.00 and rebuild the one you already have .
Old 03-23-2018, 07:57 AM   #9
bubbasimms
Well, lets explore that a bit shall we....
I haven't found anywhere to buy a new spring, flapper valve or the little pin that holds the spring. Are they available?
Old 03-23-2018, 09:08 AM   #10
Grumpy old man
use the small block studs 3-pack drill and tap $15.00 , the spring is available about $20.00 whats wrong with the rest of it ?
Old 03-23-2018, 10:28 AM   #11
Jason Banks
Have you ever replaced the bushing on the shaft? Mine was a major leak point. Does someone sell the bushing?
I ordered new studs from mcmaster to bold the intake on...either that or they were included with the new manifold. Can't remember.
