Old 03-25-2018, 10:08 PM   #1
69BUCKET
Power steering lines...help
Running a stock 69 steering box, 5.3 engine and pump. I have fitting adapter for pump...anyone have a link for what hoses guys are using?
69BUCKET is offline   Reply With Quote
Old 03-25-2018, 11:13 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Power steering lines...help
Just use the factory 69 hoses.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-25-2018, 11:38 PM   #3
69BUCKET
Fitting on hose is angled opposite direction...just wanted to get new lines...at least the pressure one.
Old 03-26-2018, 02:45 AM   #4
ls1nova71
ls1nova71's Avatar
What hose? If you take the fitting out of the pump and replace it with your original one, then the lines will bolt up like stock. The pump should be in just about the same location it was originally.
Old 03-26-2018, 10:58 AM   #5
SlowGreen71
Junior Member
Take both of your hoses to a hydraulic shop. They can cut off both ends and braze them to swivel crimp fittings. Most will require you to use a new hose. It seems there may be two different style of pumps? I've heard multiple people say to unscrew the fitting on the pressure side. Mine was not removable. It was out of a 2001. My routing did change to under and out the front of the pump. I ended up with the stock ls hard line coming out the front of the pump to a swivel crimp, new hose to the original steering box side the pics help.
SlowGreen71 is offline   Reply With Quote
Old 03-26-2018, 11:36 AM   #6
69BUCKET
Exactly what I'm dealing with. Do any parts stores make these lines...Napa?...
Old 03-27-2018, 10:49 AM   #7
truckdude239
truckdude239's Avatar
i just swaped the fitting in the back of my pump so i could use the stock 1971 line that way i can always gett a replacement if im away from home
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
