LED Tail Light Question
I would like to put LED tail lights in my 72. I have an LS swap in my truck though. I have read that the LEDs will cause an issue with the torque converter lockup and that you have to put resisters in to use LEDs. I have never used inline resisters. Would anyone with experience please chime in to help me out. What size resister, how many, does it go on the ground side? Thank you in advance.
Re: LED Tail Light Question
I'm using the sequential rear turn signals from Brother's. I did have to install a solid state flasher and keep the front turn signal 1157 bulb. I kept the front bulb because I didn't want to use the load resistors. No problems with interfering with the trans. But then again I'm using a 700R.
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
Old member
I'm all LED's and 6.0 with 4L80E transmission with no problems that I know of.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5 | |
Old member
![]() Quote:
I put LEDs in the rear of mine with filaments everywhere else. Didn't change flasher or anything. It all works great.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#7 | |
Old member
![]() Quote:
I have had my truck for about 5 years with all LED's and this is the first time I have ever herd of it being a problem for the transmission.
Yeah that's some shifty information...
I appreciate all the information. I was doing some reading a while back and someone had an issue with their torque converter lockup on their 4L60E. After some troubleshooting they found the problem to be not having enough resistance in the brake light harness because of their LED tail lights. Thank you for everyone’s input.
#10 | |
If you are going to use LED tail-lamps, use the digital flashers someone posted above. If you have trouble with the turn signals flashing too fast or not at all, add a load resistor. If your having trouble with the torque converter after all this and you have verified it in a scanner, then add a relay with pull-up/pull-down resistors depending on your situation.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
#11 | |
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
I know all LEDs is a problem with the late 90’s cruise control modules unless you wire in a relay. I can’t imagine why it would be a problem with torque converter lock-up. Unless you are using some aftermarket lock up controller that finds ground through the brake light circuit.
#14 | |
#15 |
I didn't have any trouble with my LED tail lights and the 4L60E I had until I added the cruise control. Then, the cruise didn't work and I had to add a resistor to the ground side, I believe it was. I've been told a light under the dash works too, but I just used a resistor.
No issues on the new truck, running LED's everywhere. The cruise control is, however, the new plug and play from Dakota Digital and just piggy backs on the electric throttle. I haven't had any issues (yet). |
#16 |
I have a 383/700R4 with rear LED lights and I have had zero issues with it
Brian Ritter |
#17 |
Use the brake light switch circut to control a relay for the TCC and brake lights.
