04-01-2018, 04:22 PM | #1 |
c30 cab size
Hello everyone,
I have a standard bench seat in my 1967 k1500. It is that original standard folding bench seat with basic thin molded foam bottom and coil spring back with cotton batting for a pad. I have the opportunity to purchase a used seat out of a 68 C30. I've seen pictures of the seat springs, it is a 67 68 folding seat, coil back but the bottom has a little different spring set up and better cushion. My question and concern is headspace clearance. Is the cab on the C30 a larger cab or different floor configuration that would make installing this seat a mistake inasmuch as you would be looking through the top of the windshield thanks |
04-01-2018, 06:34 PM | #2 |
All about them K’s
Re: c30 cab size
10-30 are the same cab.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
04-01-2018, 09:02 PM | #3 |
Re: c30 cab size
thanks
