Old 04-01-2018, 05:06 PM   #1
Chilly178
Chilly178's Avatar
What HEI Distributor for 5.7 vortec
Hi i'm planning on doing a 5.7 vortec swap in my 72 C20. I'm gonna run it with a Holley 670 carb. I know the distributor has to have
a melonized gear. Any suggestions on what is good/ will work? Also will any HEI distributor work with a electric tach? Was looking at these. https://www.summitracing.com/search/...9%2B4294944551
Chilly178 is offline   Reply With Quote
Old 04-01-2018, 08:21 PM   #2
Mike C
Mike C's Avatar
Re: What HEI Distributor for 5.7 vortec
My first choice would be the MSD Streefire which is usually about $160. It has the melonized gear same as the rest of their distributor line. Also comes with springs and bushings to adjust the mechanical advance curve and an adjustable vacuum advance canister.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-01-2018, 08:26 PM   #3
Chilly178
Chilly178's Avatar
Is this the one you are talking about? https://www.summitracing.com/parts/m...make/chevrolet Says it has a iron dist gear instead of melonized.
EDIT: Found this melonized gear for it https://www.summitracing.com/parts/a...6413/overview/ I think it would work if I got the melonized gear and swapped it. Any thoughts?
Old 04-01-2018, 08:54 PM   #4
Mike C
Mike C's Avatar
That one. Interesting as it looks like it comes with a different gear now than when I bought mine?
I guess if you are going that way I'd call Summit and ask. The 8561 is the Melonized steel gear and that one looks like the 8531 iron gear.
The Q&A says OK to run on anything but billet roller cam. But I'd still call. I called Comp about mine and they said good to go, but I'd hate to steer you wrong.
Summit's answer is no for your roller cam. So don't listen to me! I'm headed off to find paperwork on mine and double check what I got before I break my motor in and maybe ruin my cam!
OK, I have read even more in the questions and summit says OK for Hydraulic Roller Cam. But in November of last year they stated is was a steel gear.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-01-2018, 09:04 PM   #5
B. W.
B. W.'s Avatar
The GM melonized gear you linked to is the one I'm running on a vortec/stock HEI.
B. W. is offline   Reply With Quote
Old 04-01-2018, 09:17 PM   #6
Chilly178
Chilly178's Avatar
Ok cool. I think I'm just gonna get them both and swap the gear over. 40 bucks for some piece of mind isn't much. Hey Mike the shaft diameter on the two gears you listed is .500. The AC Delco one I listed is .491. Says here in the questions that the shaft diameter is indeed .491 for the 8362. https://www.summitracing.com/parts/m...nswers/?page=4 This thing will clear my firewall right in a 72 C20 350?
