Old 04-03-2018, 07:27 AM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up Adding to the C20
I got the spare 2-6 volts hooked up to the winch so I started on my next little project.
AIR:
I bought a older air ride system back several years ago that I was going to install on my 71 C10 but never have and probably never will.
I decided the ramp needed a air supply so. I put together a small system to supply air if needed on the road.
Going to have 120PSI when done on a 3 gallon tank with a auto cutoff for it. Going to run the hot off the contactor for the winch to a relay to power it then to the pressure switch then to compressor. I wire so it only has 12 volts when the truck is running.
Will mount everything under the bed and have brackets for the compressor to sit level.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-06-2018, 06:08 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Adding to the C20
I got the extra batteries on the ramp running off the truck battery and charging when I flip the switch on the dash. I also hooked the compressor off the contactor switch to run the air tank compressor so I'll have air when ever the truck is running and charging the battery.
I have 25' of hose so that should cover about any kind of road side air problems!
Old 04-06-2018, 06:56 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Cool! Next time you see a hottie in Daisy Dukes at the side of the road with a flat tire, you'll be all set!
~Steven
Simi Valley, CA
Old 04-06-2018, 10:44 PM   #4
Andy4639
Old member
Andy4639's Avatar
You got that right!
