Old 04-03-2018, 02:43 PM   #1
69BUCKET
Injectors
So my harness nightmare continues from shop I got package from. They sent me a harness that obviously was not to engine as injector plugs don't match them. There solution is to send me different injectors. Is there any problems with just swapping out injectors?
69BUCKET is offline   Reply With Quote
Old 04-03-2018, 03:44 PM   #2
Ghost's68
Ghost's68's Avatar
Re: Injectors
Injector height, different flows will also require the computer to be flashed for proper scaling. I think if the computer isn’t flashed it will run like crap. You can’t just ask for a refund and go elsewhere? I would be upset from the sounds of all your troubles
Ghost's68 is offline   Reply With Quote
Old 04-03-2018, 05:23 PM   #3
69BUCKET
Re: Injectors
I'm frustrated with myself. I could have done a harness myself and find an engine and saved money....or get one from a more reputable place that offers a warranty as well. The computer has been flashed...but I am going to clean this greasy harness and hope for the best. Correct Injectors are being sent today...we'll see.
Old 04-03-2018, 05:59 PM   #4
ls1nova71
ls1nova71's Avatar
Re: Injectors
You must have a flex fuel engine since that is a non flex fuel harness you showed a pic of. The problem is you dont know what tune you have, is it flex or not? Like the other guy said, there are differences. You're most likley going to need a good live tune to be done when you finish it up so you know its right.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-03-2018, 07:54 PM   #5
69BUCKET
Re: Injectors
The place I got the package from is tuning everything appropriately. They sent me a wrong harness the first time...a drive by wire...just sent me the wrong box. Then sent me this one, but obviously with injector plugs not matching, there's no way its the engines original harness. Why they are not sending the engines actual harness...who knows.
LS1nova, so you are saying that if the tune is for a FLEX fuel engine, and this harness is not a flex fuel, but injectors are going to be swapped to non flex injectors...I'm going to have problems??..
Old 04-03-2018, 08:31 PM   #6
dayj1
Re: Injectors
Flex fuel injectors are taller than regular (non-flex-fuel) injectors. The fuel rails (and pressure regulator if you have the return style fuel rail) are different. Unfortunately, you can't just swap injectors by themselves.
dayj1 is offline   Reply With Quote
Old 04-03-2018, 09:48 PM   #7
69BUCKET
Re: Injectors
Can this be comfirmed...I will need the non flex rails, injectors, regulator...
Old 04-03-2018, 10:40 PM   #8
4x4k30
4x4k30's Avatar
Re: Injectors
you best bet would be to find a complete used intake like you need and swap it.
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 04-03-2018, 11:05 PM   #9
ls1nova71
ls1nova71's Avatar
Re: Injectors
Need any more conformation? Flex on bottom, regular on top. Although it may be a year thing because I was thinking the older ones with the plastic fuel rail were the same, but dont have one to compare at the moment.
Old 04-03-2018, 09:27 PM   #10
robertsjm711
robertsjm711's Avatar
Re: Injectors
Also flex fuel injectors flow at a higher rate, that is what I have on mine.
Part # 25326903
I didn’t know I had a flex engine until I got in to the harness and injectiors, and my time guy wanted to know what I had for the tune.
It was said that if you cut off one hydra head, two more grow back.
-Lernaean Hydra
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=743246
robertsjm711 is offline   Reply With Quote
Old 04-03-2018, 11:14 PM   #11
69BUCKET
Re: Injectors
Nope...
Thank you nova...this confirms I have flex engine and they sent me non flex harness.
Old 04-03-2018, 11:40 PM   #12
ls1nova71
ls1nova71's Avatar
Re: Injectors
I would have them get you the correct harness rather than trying to change the injectors, rail, regulator, etc......
Old 04-04-2018, 12:02 AM   #13
69BUCKET
Re: Injectors
Exactly what i'm going to do...thanks for all the help fellas.
Old 04-04-2018, 12:14 PM   #14
69BUCKET
Re: Injectors
These guys are saying they have replaced only injectors with no issues....is this possible?...
Old 04-04-2018, 04:14 PM   #15
dayj1
Re: Injectors
I'm sorry, but the answer is still no.
Here's a thread with pictures that show that the regular injector won't even seat in an intake with flex fuel rails (because the injector is shorter).
https://www.performancetrucks.net/fo...r-help-498646/
Old 04-04-2018, 06:43 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Injectors
From what I've read, its best to pretty much ignore what they've said...as most of its been contradicted or corrected here. Ask them for the correct harness in full. Or a refund at this point.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-05-2018, 09:55 AM   #17
69BUCKET
Re: Injectors
In response to nova...I do have the plastic rails. Maybe because it's older rail...both style of injectors fit? I received them LATE yesterday so I will find out shortly IF THIS is true.
Big thanks to everyone helping out....best forum out there.
Old 04-05-2018, 12:16 PM   #18
ls1nova71
ls1nova71's Avatar
Re: Injectors
I just dug out my older plastic flex fuel rails, and they're ever so slightly different than the non flex rails and the injectors in them are about 1/4"taller than the non flex injectors too. So I'm going to say it isn't going to work.
Old 04-05-2018, 01:10 PM   #19
69BUCKET
Re: Injectors
Thanks nova...done messing these guys.
