Old 04-15-2018, 10:08 AM   #1
Rotortrash
Rotortrash's Avatar
inline 6 intake/exhaust bolts
I bought a 67 with an inline 6 and it has the wrong bolts on the intake/exhaust.the intake and the exhaust manifold leak. I can't find anywhere to buy new or used. any help would be greatly appreciated. Bolts with the weird washer things is what I'm after.
Rotortrash is offline   Reply With Quote
Old 04-15-2018, 10:16 AM   #2
Jason Banks
Jason Banks's Avatar
Re: inline 6 intake/exhaust bolts
Become a supporting member - here - http://67-72chevytrucks.com/vboard/payments.php
Post a WTB(Want to buy) in the parts board.
You can order standard studs and bolts once you have the clamps.
Here is a thread with some pictures. http://67-72chevytrucks.com/vboard/s...d.php?t=454785
Jason Banks is offline   Reply With Quote
Old 04-16-2018, 12:43 AM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
Not sure if i saved the ones off my old 250 Not sure witch one i had in year
stsalvage is offline   Reply With Quote
Old 04-16-2018, 05:22 AM   #4
BCOWANWHEELS
after you find the fasteners it wont cure the manifolds leaking. you have to take both manifolds to a machine shop then have the center where they bolt together ground flat, install a new gasket then surface both manifolds bolted together where it meets the head. tighten it down from the center outwards. then retorque several times after getting it hot.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
