Request for Picture - '55 2nd Series Front Bumper Bracket
I need a picture of a long side front bumper bracket as-installed. I have the brackets but I had filled the mounting hole when I boxed the frame.
...and yes, it's going to be interesting to get a nut on the inside of the boxed frame. After drilling the thru hole, I suppose I'll goop the nut up with J-B Weld, tape it to a stick, put it in place and use a bolt to hold it there until it nearly dries. See how nice and pretty -- and non-functional I made it? Thanks in advance,
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) Last edited by DransportGarage; 04-20-2018 at 04:23 AM. |
Re: Request for Picture - '55 2nd Series Front Bumper Bracket
I have those dimensions at home so I can get them.
how about using a long nut, like used on threaded rod, accessible from a through hole in the frame from the outside, like a hole was drilled right through, then enlarged to fit a nut through. |
#3 | |
Interesting idea on the long nut. We'll see once I dig in...
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
here are a few pics, sorry, the square was upside down so you get metric. google can help translate if required.
looks like 2" apart though. I think the bracket is supposed to attach to the inside of the channel. you may have some messing around to get the brackets to fit a boxed frame. might be worth fabbing some new brackets or simply cut the boxing out of that area. |
looks like 7/8" in from the front edge of the frame and the 2 holes are midline in the frame channel.
help? |
looks like the center of the bottom hole is 1 1/8" up from the bottom.
help? |
