04-21-2018, 01:06 PM | #1 |
Blazer rear Tank, filler and venting
I’m trying to finish up this tank relocation that was started by previous owner in my 70 gmc 1/2t lwb. I’ve got the bed crossmember notched out. Now I’m working on adding a fill, venting etc. I’m gonna put a metal box in the bed rear of the drivers side wheel hump. That will be the shortest route to the tank, should be downhill the whole way. I’m using a .50cal ammo can that I will trim up to fit, then mount it against the bed floor/inside bed wall. I’ll mount a marine stainless filler neck on top.
Couple of hiccups. 1. The 1 3/8” filler neck on the tank is an odd size for finding a hose. Plan to use small piece near tank, then have muffler shop do a custom bent pipe swaged (is that he term) to 1 1/2”. That way I can run a small piece of 1 1/2” hose between filler neck and pipe. 2. I’d like to vent the tank on both sides. I’ve heard if u don’t that are a pain to fill. My plan is to use some fuel hose up to a rollover valve. Mount it high (I think higher than the fill level is required?) Any links to what you guys have used?? Trying to keep this inexpensive but functional. Also, I’ve got short legs and short arms so putting the filler directly on bed floor is not an option. I also don’t want it in the wheel well |
04-21-2018, 08:52 PM | #2 |
SWB 4x4 Collector
Re: Blazer rear Tank, filler and venting
You could weld in a blazer/truck fuel door.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
04-21-2018, 09:53 PM | #3 |
That would be the cleanest. But the only welder I have is a harbor freight cheapy flux. And my welding skills are minimal. Plus I plan to replace this bed in the next year. It is is really rough. Just trying to get the truck functional and driving for now. I think I’ll do the blazer door (or some kind of door) on the next bed. |
04-22-2018, 12:09 AM | #4 |
if your going to replace bed soon, i`d just rig up a filler in the wheelwell behind tire.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
04-23-2018, 11:35 AM | #5 | |
Here is my box I plan to mount the filler in. It was a .50cal ammo box. I had to do a makeshift brake to make the bends. Now just need to track down some hose and get some exhaust pipe bent and swaged (I think that's the term). Need 1 3/8" hose at the tank, and a piece of 1 1/2" hose at the filler neck. |
05-07-2018, 02:13 PM | #6 |
Update: I'm close to putting the bed back on.
My filler doesn't have a vent. From what I have read, I should do TWO vent hoses? One on each side of tank? There are actually 3 lines coming off the tank, guess I will plug the extra on drivers side. I have a couple boat vents I picked up, but they aren't rollover valves. I'm guessing I need a couple rollover valves, then mount them up high in wheel wells (above where the filler top is?)? |
05-07-2018, 02:46 PM | #7 |
I did the ammo can thing as well, I don't think it will look bad once the bed is coated.
05-09-2018, 09:55 AM | #8 |
Looks like yours is a bit shorter. Hopefully mine isn't too tall and the gas station filler has enough room under bed rail. We shall see. I'm bolting mine on so if it is a problem, I'll yank it off and trim it down.
04-23-2018, 01:31 AM | #9 | |
Not sure how much work you want to do, but I've seen some guys making custom brackets to conceal the filler behind the tailights.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
04-23-2018, 02:48 AM | #10 |
I used a Blazer fill pipe like above And will eventually Weld in the original hole for the in cab tank. For now there is the old gas cap in the hole drilled through and plated on the inside to hold it in. Of course this means you have to drill a big hole in the side of your bed and in the floor of your bed but I had a Blazer to use for the template.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-23-2018, 05:22 PM | #11 |
Got the bed on last night. Then went to hookup the fuel filler line I had come up with. Just not gonna work. The 1 3/8" hose that connects from end of exhaust pipe to fuel filler on tank is crimping at the bottom. Needs another bend.
Do I search for some flexible 1 3/8" fuel hose? Do I fabricate (or more accurately have fabricated) another additional piece of 1 1/2" pipe, bent at the end then have another 1 3/8" adapter welded on the end of that (then trim off the existing 1 3/8" end on existing pipe)? This would add a new metal pipe in the mix and require an additional hose union. Do I scrap the existing pipe I have, have a new one fabricated with 2 bends and a new 1 3/8" adapter welded on the end? This would have to be dead on as far as length and bends etc. Do i scrap this whole "mounting a fuel filler in a box idea" and find a simpler place to add a filler? Just want to drive this thing and be able to add gas as needed. Also, I was planning on putting the 1/2" vent line hose up in the fender (rear of fenderwell). How do i attach/secure the end of the vent hose? Also, don't forget that this bed is trash so I will probably replace it once I have a driving truck to pickup another bed. So anything I do I would like to be able to move it over to the new bed. |
05-23-2018, 05:50 PM | #12 |
I found this setup on line and I’m gonna try to pull it off. Not sure how easy it’s gonna be but well find Out. I don’t know who did it to give them credit
05-23-2018, 06:18 PM | #13 | |
All of those require more work/fabrication than I want to do (especially on this crap bed). |
05-25-2018, 11:55 PM | #14 |
Finally think I have it!!
I had muffler shop cut and weld another 1 1/2” piece to another 1 1/2” to 1 3/8” adapter. I had them weld it at downward angle. This piece lined up right by the tank fuel filler. Then I use my previous bent pipe and connected that to this new one. I have 3 fuel hose junctions. One above bed at fuel filler, one connecting two metal pipes and another connecting to filler on tank. Hope that makes sense. Anyway, it looks pretty good to me. Haha I’ll post pics tomorrow. For some reason I can’t post pics from my phone because of some token issue. |
