Old 04-24-2018, 01:33 PM   #1
Kinger615
Bigger ball joints ?????
My lower ball joint on my 63 fits a little loose.Dowa Anybody know who might sell a oversized one? I called Moog and they have nothing. Anybody else having this issue ?
Kinger615 is offline   Reply With Quote
Old 04-24-2018, 11:37 PM   #2
Captainfab
60-66 Nut
Re: Bigger ball joints ?????
Is it loose in the spindle or in the lower control arm? I think you will just have to replace the part that is worn.
Old 04-25-2018, 06:33 AM   #3
bonehead
bonehead's Avatar
if the ball joint socket is not worn beyond repair, you might be able to re-ream the taper so the joint just sits slightly lower, but solidly, in the tapered socket.
This would only work for minor damage to the taper. FWIW
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 04-25-2018, 07:34 AM   #4
On my old 70, I put a few tack welds in the a-arm area, then smoothed them out and it basically rebuilt the taper area and the ball joint fit in the socket hole tightly again.
Palf70Step is online now   Reply With Quote
Old 04-27-2018, 10:08 PM   #5
dodgiesdad
dodgiesdad's Avatar
I had off-road truck I had to gusset the socket on the upper A arm and tack weld the ball-joint into. With out doing that I kept blowing the joint out on landings.
dodgiesdad is offline   Reply With Quote
Old 04-27-2018, 10:18 PM   #6
rvrfoot
Do you have any pictures?
rvrfoot is offline   Reply With Quote
