help withcoolant temp sensor wire routing
can someone post a pic of how the factory routed the green coolant temp wire. I have a bracket for it but not sure where it goes. thanks in advance for your help.
69 step side http://67-72chevytrucks.com/vboard/s...d.php?t=613407 |
#2 | |
Old member
![]() Quote:
The ones I've ever seen ran along the top of the intake along the valve cover bolts to the rear of the motor then up the fire wall to the gutter and over to the fuse block through the fire wall. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
The Older Generation
Re: help withcoolant temp sensor wire routing
There is in fact a bracket. At least on the V-8's there is. The wire runs along the intake manifold as Andy said but it runs down over the front of the head and there is a bracket that fastens to the bottom water pump mounting bolt, then the wire goes under the #1 spark plug and back up to the temp sender. This is to keep it away from the exhaust manifold..... The bolt in the water pump is a special bolt that has a stud on the head so the bracket can be secured to it. There is also supposed to be a cloth type sheath over the wire to protect it from chaffing. I will see if I can get a picture in the morning. LockDoc
![]() Join Date: May 2010
I agree with Leon and Andy regarding routing. In addition, the wire was originally enclosed in a fabric loom from the harness to the sender. The loom was also, at least on my original '69 350, retained by 2 clips on the valve cover which can be seen in the 1st picture below. The 2nd picture shows the wire/loom passing through the water pump bracket.
thanks every body, any more pics would be great as well
#6 | |
![]() Join Date: Feb 2016
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
