Old 05-18-2018, 05:55 PM   #1
72bigred
Hood support inserts
Just wondering what is being used as the hood inserts for under the braces on this 60 hood. I have a set of these foam type pads but they do not offer the support to keep the hood as straight as it should be. I would like to get something in there to get it stiff enough to actually block it out and shoot it and these foam inserts are just not cutting it. I have it shimmed up currently with door shims but they obviously cannot be permanent and would like to put something in there and be done with it.
Thanks in advance
72bigred is offline   Reply With Quote
Old 05-18-2018, 11:46 PM   #2
Captainfab
60-66 Nut
Re: Hood support inserts
I don't know if they have an minimum order requirement these days but I would check with these guys for a thicker or stiffer foam. They're there in Spokane.
http://www.trueseals.com/
Old 05-19-2018, 09:48 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
You mean the foam under the hood braces?
Old 05-19-2018, 01:39 PM   #4
damnyankee36
damnyankee36's Avatar
How about bending the supports upwards to minimize the gap?
damnyankee36 is offline   Reply With Quote
