05-22-2018, 05:47 PM | #1 |
running hot
I see a lot of threads about heating and a lot of opinions. What I want to know is who sells the best stock look non aluminum three row radiator? For a 1970 c10 Please reply!
05-22-2018, 07:13 PM | #2 |
Re: running hot
What size engine is it for? I have no experience, but I've heard good things about the Spectra radiator on Rock Auto.
72 C10 lwb fleetside -stock 350/350 combo |
05-22-2018, 08:09 PM | #3 |
Re: running hot
350 4 bolt main swb auto power sterring
05-23-2018, 12:38 AM | #4 |
Re: running hot
Just get a 4 core, same price.
I BELIEVE IN JOHN 3:16 |
05-23-2018, 01:04 AM | #5 |
Re: running hot
Champion radiators have a good rep on the board for being a decent radiator for a decent price. Not exactly stock looking tho. What problems are you having? Temps?
05-23-2018, 07:43 PM | #6 |
Moderator
Re: running hot
They are a great radiator. If you want it to look original just paint it black
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-23-2018, 08:32 PM | #7 |
Re: running hot
05-23-2018, 01:37 AM | #8 |
Re: running hot
Rock auto
05-23-2018, 07:44 AM | #9 |
Re: running hot
Thanks for the info. They are currently out of stock. I could be wrong but the spectra tanks looked like plastic. Are the three and four row all metal? I should be good with a three row, w/o air. Currently have a two row. I believe that is incorrect. Tends to run a tad hot in hot weather,when pulling the boat.
05-23-2018, 07:53 AM | #10 |
Old member
Re: running hot
Local O Reilly's has the stock brass radiators.
https://www.oreillyauto.com/detail/b...radiator&pos=0 https://www.oreillyauto.com/detail/b...radiator&pos=1
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
05-23-2018, 11:50 AM | #11 |
Re: running hot
Really?
Construction: Plastic Tank/Aluminum Core
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-23-2018, 05:20 PM | #12 |
Re: running hot
05-23-2018, 05:31 PM | #13 |
Re: running hot
05-23-2018, 04:50 PM | #14 |
Re: running hot
05-23-2018, 05:01 PM | #15 |
Re: running hot
on my 250 I run a 7 blade/ no clutch and 160 stat and 4 core brass/copper rad. its my work truck
05-23-2018, 05:29 PM | #16 | |
Re: running hot
checked cap pressure,is working properly getting a better guage reading now. will pull the boat as soon as it quits raining!! |
05-23-2018, 06:32 PM | #17 |
Re: running hot
05-23-2018, 07:10 PM | #18 |
Re: running hot
2 left heads doesn’t make sense to me. From factory, temp gauge sending unit is on driver’s side towards the front of the truck, or left side of head. Passenger side has temp light sending unit towards the rear of the truck, or left side of head once again. So does that mean factory used 2 right side heads on our trucks? I’m guessing you have heads from a different application then? Running the numbers on the heads will tell you for sure.
05-23-2018, 07:33 PM | #19 |
Re: running hot
The sbc engines have only heads (there is no left/right distinction)
That said the only differences might be if the older heads don't have all the accessory bolt holes in the head ends like the newer ones do.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights |
05-24-2018, 04:01 PM | #20 | |
Re: running hot
05-24-2018, 08:55 AM | #21 | |
Re: running hot
If I were you I would get rid of that flex fan ASAP. |
05-24-2018, 04:09 PM | #22 |
Re: running hot
05-24-2018, 05:03 PM | #23 |
Re: running hot
They're known for coming apart and causing serious damage in the engine bay
05-23-2018, 07:37 PM | #24 |
Re: running hot
lol sbc n bbc heads are same
05-23-2018, 11:36 PM | #25 |
Who Changed This?
Re: running hot
There's gonna be a pipe plug in the head that doesn't have the hole open for the temp sender. Easy to sort out, right?
