05-23-2018, 07:49 AM | #1 |
Sway Bar - Factory Power Assist
I recently bought a CPP bar and realized it would not work with my factor power assist (Power steering). CPP has offered to return it for me (great support and customer service), but now I'm stuck with no front sway bar.
Anyone know of one that is compatible with power assist? Or do I need to cut up this CPP Bar and extend it to make it work? 1965 C10 with Air Ride |
05-23-2018, 07:53 AM | #2 |
Check The Champ, Demonstrator
Re: Sway Bar - Factory Power Assist
Great question but no pics? Is your truck lowered?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
05-23-2018, 07:58 AM | #3 |
05-23-2018, 02:37 PM | #4 |
It's Better With Nitro
That's a tough one. A lot of the GM vehicles with the power valve and ram-type power steering used a sway bar that mounted to the opposite side. My '63 Tempest uses the same time of power steering and the factory front sway bar mounts to the rear of the A-arms. I know that doesn't help with what is currently available on the market, but if you want to keep your OE power steering assembly, I would start thinking of doing a rear mount sway bar configuration.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
05-25-2018, 09:56 AM | #5 |
Active Member
Consider removing the sleeve and associated rubber and washers so the bar bolts directly to the top of the control arm. Worked for me. See post # 8 for pic.
http://67-72chevytrucks.com/vboard/s...d.php?t=764102 |
05-29-2018, 07:01 AM | #6 | |
Thanks |
06-01-2018, 12:52 AM | #7 |
The 64 to 66’ C10 and 20 trucks with power assist came with front sway bar, e.g. 66’ Custom Camper, or had it available as an option. It is the same type as the 1 1/4 bar referenced above, only smaller in diameter. The factory lower control arms may already have holes for mounting the sway bar. The photos below are of a 65’ C10 with power assist steering and factory sway bar.
Photos show how connect to lower control arm, and their is a bracket on the bottom of frame rail that also attaches to the bar ( you can just see it some of the photos). Can take better photos showing bar, if needed. Thanks, Les Last edited by aotte1; 06-01-2018 at 01:11 AM. |
05-23-2018, 02:58 PM | #8 |
Care to share any pictures?
05-23-2018, 03:12 PM | #9 |
I found this one online. Is that how yours is setup?
05-23-2018, 09:05 PM | #10 |
How about using an 1 1/4" factory front sway bar off a 1987 & down 1 ton truck? That's what I used on my 64 C-10 and the factory sway bar bolts flat against the lower control arm. The holes are already drilled for it in the lower control arm. Skip that - I used 73 lower control arms in my truck - I can't remember if the 64 lower control arms were pre-drilled or not. I'm on stock height 73 front springs but have 2 1/2" drop spindles. Oh and the sway bar was $15.00 from Pick N Pull during 1/2 of weekend. As a matter of fact Pick N Pull is having a half off sale this Memorial weekend starting Thursday the 24th through the 28th if there are any Pick N Pulls near you. just a thought.
05-23-2018, 09:11 PM | #11 |
Thanks. I was talking with a buddy today and he made the same suggestion. I’m going to look at my brothers 85 this weekend and see if it will work. If so I plan to hit up a pull a part this Friday.
06-18-2018, 11:22 AM | #12 |
Les it was great meeting you and seeing your projects. Thank you for the sway bar sir!
My CPP bar will be available for sale if anyone is interested; just PM me. |
06-18-2018, 11:43 AM | #13 |
Will it work if you dont use the rubber spacer? Will there be room if you just bolt it to the lower arm?
06-18-2018, 11:45 AM | #14 |
