Old 05-24-2018, 01:50 PM   #1
plr1112
vehicle build date question
I would like to know if there is way to find out the build date for a 1969 truck?
I do not have the build sheet that was installed under the seat. Could the build date be found somewhere on the SPID glove box sticker?
Thanks!
plr1112 is offline   Reply With Quote
Old 05-24-2018, 03:17 PM   #2
rustytruck50
rustytruck50's Avatar
Re: vehicle build date question
Good question....so far as I know, there are only two places you can find the build date on these trucks...first and best place is the build sheet & the other place you can check is the blue label on the door latch side of the driver's door, about half way up the door. Otherwise, you can get close if you can locate any date stamps on things like the transmission, engine, rearend or even the carburetor. Hope that helps.
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 05-24-2018, 05:20 PM   #3
plr1112
Thanks for the info, I will check the date code on the rear end and transmission. My truck does not have the blue label anymore. Could you tell me where the date code is located on the rear end and transmission. Thanks.
Old 05-24-2018, 06:25 PM   #4
rustytruck50
A lot of times, the date code on the tranny is somewhere close to the pan rail or the governor cover, usually stamped into a smooth machined pad while the rearend would have something stamped in a similar area close to the center section. I forgot to mention before that it will be a combination of letters and numbers, but there are ways to decode them. Let us know what you find.
-Doug
'05 RCSB Sierra 2WD
Old 05-24-2018, 09:13 PM   #5
MusicMan70
MusicMan70's Avatar
If you have the woodbox, there is a date code stamp there as well. These are from a 1970 and 1973 GMC
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 05-24-2018, 11:21 PM   #6
plr1112
I have good news. Everything is starting to fall into place.
The 12 bolt rear end: RA 11 29 W
Turbo 400 tag:
335
CJ-69- 6798
I take as the 12 bolt; November 29, non posi
Transmission; 335th day witch is late November, CJ- big block, 1969
My 396ci engine date code: T1120YP, November 20, 1969 (Truck)
Can you guys help me finish decoding the rear end and transmission.
Thanks.
Old 05-27-2018, 09:41 AM   #7
bruceman1968
bruceman1968's Avatar
plr1112, Looks like you got it pretty well figured out.
RA= 3:07 open
11= Nov
29 =29th of Nov
W= Warren Gear
Turbo 400 tag:
335
CJ-69- 6798
335 =Nov 30th 1968
CJ=Big Block, Chevy Truck, 10,20,30 series
69 = 1969MY
6798= Trans serial number(this number is unique to your trans)
T =Tonawanda engine assembly plant
YP = 1969 396ci, 310hp, th400 trans, L47 RPO, 4bbl carb, 10, 20 30, series.
Thanks.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 05-24-2018, 11:26 PM   #8
jocko
jocko's Avatar
Also recommend send member SSTim you VIN, he may be able to approximate it.
Old 05-25-2018, 12:32 AM   #9
plr1112
MusicMan70,
I actually have a steel bed.
Old 05-25-2018, 09:18 PM   #10
rustytruck50
Cool...looks like you are making some progress!
-Doug
'05 RCSB Sierra 2WD
Old 05-26-2018, 12:50 AM   #11
mike16
if a truck has its protec-to- plate.will it be shown on there?
mike16 is offline   Reply With Quote
Old 05-26-2018, 09:25 PM   #12
rustytruck50
Unfortunately not...just the sale date & the other usual info that makes them neat to read
-Doug
'05 RCSB Sierra 2WD
Old 05-26-2018, 09:32 PM   #13
bruceman1968
1969 Chevrolet truck Protect o Plates have a code for the build month on them. But not the build week or date. Just the build month.
Old 05-27-2018, 12:17 AM   #14
FirstOwner69
FirstOwner69's Avatar
That's news to me. Where is it? Is it the letter "D"? Note that mine also has the miles at delivery rather than delivery date.
FirstOwner69 is offline   Reply With Quote
Old 05-27-2018, 09:08 AM   #15
bruceman1968
Yes Jim. The D is for December.
1 thru 0(zero) for January thru October, N for November and D for December. You can see the other dates on your Protecto o Plate are for the end of November. Nov 30th on your engine assembly, Nov 20th on your rear axle and 328 is the Julian date for your Trans which is the 23rd of Nov. (1968 was a leap year)
The R is for Rochester and the Chevrolet bowtie is the makers mark.
Old 05-27-2018, 02:48 PM   #16
FirstOwner69
Thanks for the info.
Incidentally, part of the reason I posted my Protect-O-Plate is that my dates are pretty similar to his, and I'm wondering if the OP's is also a Fremont truck since he's in California. As I've said in some other posts, I contacted Chevrolet soon after I purchased my truck in 1969 to ask why my CST was missing some CST options (specifically, deluxe and lighted side markers, headliner and cargo light). The response was that my truck was a mid-December build and those options were added a week or 2 later. Unfortunately, I don't recall the exact date they said my truck was built but think it was Dec.12th or 13th.
Perhaps this will help the OP zero in on his build date, especially if his is a Fremont truck. His dates appear to be a week to 2 weeks after mine.
Old 05-26-2018, 11:29 PM   #17
57taskforce
All about them K’s
57taskforce's Avatar
SStim was able to nail mine down pretty good.
Tyler
Old 05-28-2018, 05:00 PM   #18
Mudflat
Mine is a 69, no wires, appears it was never lighted.
Mudflat is offline   Reply With Quote
build sheet
