Old 05-28-2018, 02:04 PM   #1
Trackman101
Trackman101's Avatar
AC vacuum control head Q.
By design should the ac vacuum controller switch hold vacuum in the ac position even when the truck is shut off? Mine doesn't , I am trying to test to see if the switch is leaking.
My engine doesn't make a bunch of vacuum and when I am doing some spirited driving (ac on) my vac canister doesn't have enough supply to keep my heater valve closed. When the truck is idling or cruising I have enough vacuum to keep it closed. I have confirmed my canister holds vacuum, no leaks at the heater or door vent diaphragms.I have the 2nd vac port on the head plugged.
Trackman101 is offline   Reply With Quote
Old 05-28-2018, 02:45 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: AC vacuum control head Q.
Invest in a vacuum can and it should be good to go. Put a check valve in line so it can't bleed off.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-28-2018, 03:42 PM   #3
Trackman101
I have the stock vacuum canister. It works as it should. I can't seem to find anyone who sells just that vacuum switch.
Old 05-28-2018, 04:45 PM   #4
dmjlambert
dmjlambert's Avatar
What port are you getting vacuum from on the carburetor, or are you getting it from the intake manifold? Can you show a picture of where the vacuum line is connected to the engine? Do you think the vacuum switch on the A/C controller is leaking because you hear a hiss from it, or do you think something else is going on?
Old 05-28-2018, 05:47 PM   #5
Trackman101
I've isolated down to the vacuum switch. Now to track one down without having to buy the whole a/c heater switch assembly.
Old 05-28-2018, 09:28 PM   #6
Andy4639
Old member
Andy4639's Avatar
Manes truck parts use to have them.
Old 05-28-2018, 11:11 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: AC vacuum control head Q.I
I've bought the vacuum switch from local AC shops that have a parts department open to the public. Even at retail, they aren't that pricey.
~Steven
Simi Valley, CA
Old 06-01-2018, 09:01 AM   #8
Trackman101
I struck out trying to find just the vacuum switch. I did score an ol ac/heater switch assembly for cheap and stole the vac switch off of it. I've got it back together yesterday and tested. This morning the system is still holding vacuum. Fixed!
