06-08-2018, 08:39 AM | #1 |
63 C10 alignment question
Does anyone know what the caster setting is. By that I mean is it positive or negative lean caster? Does the spindle lean forward or back to create the caster rate? Also, what should it be set at?
06-08-2018, 09:17 AM | #2 |
Re: 63 C10 alignment question
Pos 2°27' Caster, Pos 0°15' Camber, Toe in 3/16. Took a minute to find, hope this helps someone.
06-10-2018, 07:09 PM | #3 |
But Found Her 25yrs Later!
Thank you.
06-11-2018, 12:27 PM | #4 |
Extra positive caster will help it track straighter, so get the alignment shop to add as much as possible, especially if you have power steering. The minimal caster from the factory was to help the truck steer easier without power steering. You might be able to get 4-5 degrees with factory parts.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
