Old 06-12-2018, 05:24 PM   #1
C10Glenn
stock spring specs Help please
with my truck now in super capable hands I've been asked the question of what the standard spring spec/size/weight rating is for both front and back.
I've checked on the usual sites but can't seem to find the info - to add logic to this my mechanic is aiming to have the springs made locally, slightly lowered but to meet the same (or better) standard specs.
Hopefully I can get some urgent help
Glenn
C10Glenn is offline   Reply With Quote
Old 06-12-2018, 11:56 PM   #2
Captainfab
60-66 Nut
Re: stock spring specs Help please
I can't help with the specs but if you are going with a lowered spring I would think it would be more cost effective to just buy them from here in the US.
Old 06-13-2018, 03:59 AM   #3
C10Glenn
Thanks John, I did wonder myself, we're doing price comparisons but I agree it may well be quicker & easier just ordering from RA
Thanks for the input
Old 06-14-2018, 10:57 AM   #4
SCOTI
SCOTI's Avatar
Glenn
Spring rates aren't a "one size fits all" deal. Spring rates from the factory are determined depending on how the truck was optioned. Look up Moog replacement springs for the various rate options.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-15-2018, 06:25 AM   #5
PGSigns
PGSigns's Avatar
I did a bunch of research on spring rates and they vary a good bit based on rate and use. A hotchkis spring will be stiffer than a CPP. A good spring shop will want wheel weights, total weight, installed height and use. If you are going to auto cross the truck the rates will be stiffer than the rate on a cruiser that is looking for the smoothest ride.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
