Old 06-16-2018, 04:16 PM   #1
Freestate
Fuel Gauge Issues
All, I'm having some fuel gauge issues. Currently, I have a full tank of gas and the fuel gauge stays at 1/4 of a tank. I've done the following and it still isn't working.
1. Replaced sending unit
2. unplugged the wire from the sending unit and the fuel gauge went to full. Plugged it back in and it went back to 1/4.
3. Unplugged the sending unit wire at the fuse box and the fuel gauge went to full. Plugged it back in and it went back to 1/4.
What are my next steps to diagnosing this issue?
Freestate is offline   Reply With Quote
Old 06-16-2018, 04:37 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Fuel Gauge Issues
Pull the door sill plate at the bottom of the drivers side door opening and check the wires to make sure they are OK. The Dome light wires run under there too, check them also.....
LockDoc
Leon
Old 06-18-2018, 11:07 AM   #3
Freestate
LockDoc
Thanks for the tip. The wires look good to me. Any other advice?
Old 06-18-2018, 11:10 AM   #4
LockDoc
LockDoc's Avatar
Read Tbone's thread....
http://67-72chevytrucks.com/vboard/s...d.php?t=640615
LockDoc
Leon
Old 06-18-2018, 11:10 AM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
How long did you replace the sending unit. The new ones are known to fail because of bad solder joints which will give you a bad reading. I posted a thread on a plastic float that is a great replacement.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 06-18-2018, 02:11 PM   #6
Rich916
Rich916's Avatar
Had the same issue...drove me crazy, try grounding the sending unit.
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 06-18-2018, 04:30 PM   #7
Freestate
Smitty
Just replaced it this weekend. My next step, after testing wires, is to pull the sending unit back out and test it.
Old 06-18-2018, 09:13 PM   #8
bcfishon
Check and make sure the harness is plugged all the way in on the instrument cluster, the circuit runs through there and I have seen issues with that connection with the water temp and fuel guage.
bcfishon is offline   Reply With Quote
Old 06-18-2018, 03:46 PM   #9
tomshortwide69
I had the same problem with a aftermarket unit I found a NOS unit on ebay no more issues
tomshortwide69 is offline   Reply With Quote
Old 06-18-2018, 09:47 PM   #10
rockyrivermark
Remove the old sending wire at tank and fuse block. Then Run a temp wire to re sending unit and fuse block marked fuel
Make sure to ground the sending unit.
This way you can eliminate it was a wire issue from tank to fuse block.
Keep us posted.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 06-19-2018, 05:31 PM   #11
Freestate
Keep us posted.
Thanks for the tip. I'll give it a try next time I work on the truck and let you know. I live in one city and house the truck in another, so I only get to work on it once every few months.
Old 06-20-2018, 09:11 PM   #12
TBONE1964
Cluster King
TBONE1964's Avatar
If you have not figured this out yet, remove the resistor from the back of the gauge and ohm it. It should be in the 85-88 ohm range across the poles.
If you get less than that, replace the resistor. I suspect you will only get around 22-25 ohms, if the resistor is bad.
This is one of the more typical reasons why a fuel gauge will only reach 1/4 full when the tank is actually full.
Typically a ground issue or lack of it will cause the gauge to peg past full (around 3 o-clock position).
Truck and Car shop in Orange CA, sells replacement resistors for factory gauges
Hope this helps,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 06-21-2018, 11:33 AM   #13
Freestate
Hope this helps,
Tom
This is great info and I’ll for sure try it when I get a chance to work on my truck again. I’ll report back if this is the issue. Thanks!
Old 06-19-2018, 11:08 AM   #14
Rich69shortfleet
Make sure there is nothing interfering with the movement of the float on the sending unit.
Rich69shortfleet is offline   Reply With Quote
