Old 06-20-2018, 04:25 PM   #1
1968_K20_4x4
C60 wiring harness in a K20?
So, today I literally tried to "fire up" my truck. I stopped at the gas station and when I went to start the truck after, it cranked but didn't want to start. I turned the key off, waited for a few seconds and tried again. This time absolutely nothing happened. I tried some troubleshooting which included removing the ignition from the dash for inspection. I couldnt see anything wrong, so I decided to try and start the truck with a screwdriver at the starter motor just to get it home. I put the key to ON and left it there. But once I got out of the truck to go jump start it, I saw smoke coming out from under the dash. I turned the key off and pulled the battery cable to stop the fire. My red ignition wire was burning at the fuse box, as well as behind the ignition switch. See photo attatched ( Sorry that it's not strait but you get the idea)
After calling a tow truck to haul the truck home I went out and inspected and it looks like I fried my wiring harness Luckily that seems to be all the damage that happened. I've had this truck for about 2 years and have never had any issues with the electrical system before
So now I have some questions. First off... what went wrong? Bad ignition switch? When I had the ignition removed from the dash was it no longer properly grounded when I tried to start it?? Or???
Also, my buddy has a 1971 C60 dump truck that I can take parts from. Does anyone know if I could pull the wiring harness out of his C60 and install it in my truck? My truck is a 1968 Chevy K20.
Apparently there is supposed to be a fuse wire coming off the battery that is supposed to prevent this from happening. I don't know if I don't have that or it didn't function properly or what.
I have a little electrical knowledge but certainly not very advanced.
'68 Chevy K20
'72 Chevy K20 - Smokin' Ochre
'08 Mercury Grand Marquis - Daily driver/ Parts fetcher
Ohh uh, I didn't have time to fix everything...
1968_K20_4x4 is offline   Reply With Quote
Old 06-20-2018, 04:58 PM   #2
Barnfind46
Barnfind46's Avatar
Re: C60 wiring harness in a K20?
50 year old wiring?
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 06-20-2018, 07:03 PM   #3
projectking
projectking's Avatar
The wire that melted isn’t fused.....where does it go to?
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 06-24-2018, 11:15 AM   #4
1968_K20_4x4
So the red wire that melted comes off the battery and runs to the fuse box. It then runs to my ignition switch. From there is a pink wire which was marked as ignition so I belive it runs to the starter motor. I'll attach a couple of pics
'68 Chevy K20
Old 06-21-2018, 04:47 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
There should be a Fusable Link wire spliced into a 12- or 14 ga. wire coming from the Positive Terminal and going to the junction terminal on the Passenger side fender, where it connects to the front engine harness coming from over the radiator wall. The fusable Link there is supposed to melt and shut down power in the event of an overload or short.
If it's open, the truck should not start.
Old 06-24-2018, 11:17 AM   #6
1968_K20_4x4
Can I get this fuseable link at any part store? Do you have a pic of how it's supposed to look when properly connected? Thanks
'68 Chevy K20
Old 06-24-2018, 06:37 PM   #7
'68OrangeSunshine
Yes, Usually in a small coil in the HELP parts section.
It;s there in the pics above. A line runs off the Positive terminal on the Battery and connects to the terminal at the fender. Only about half of that line needs to be fusable link wire. You can splice it to regular copper line for the rest.
