AC Orifice Tube
I am starting to get together the parts needed to bring back to life the AC in my 83.
It looks like the system had already been converted to 134 as there are the correct manifold connectors present, but I'm going to replace the orifice tube. I need to know if the orifice tube for the R134 is the same as R12. If not, anyone have the part number of the tube I would need? I'm going to be replacing the dryer, hoses, evap unit & condenser as well as installing a Sanden 508 type compressor.
1997 GMC Sierra Ext 1965 Mustang |
Re: AC Orifice Tube
it will work with the stock one, but a slightly smaller orifice works better. stock is .072. a 38621 is .067, or a 38635 is .062, which is what I am running in my truck. With the sanden I would run the .062 it will work great.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#3 | |
Re: AC Orifice Tube
Never mind....found it....thanks.....
Re: AC Orifice Tube
Re: AC Orifice Tube
Bought all the replacement parts from Rock Auto & eBay
![]() Join Date: Jun 2016
Re: AC Orifice Tube
They are color-coded by size. Get the blue one.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
#7 | |
Re: AC Orifice Tube
A system with an accumulator will use an orifice tube. I'm not totally sure that I'm correct on this but I feel pretty certain that I am. One problem is that there is SO much MISinformation out there that it's really difficult to know what you have, how it's supposed to work and so forth. I honestly believe that the industry does NOT want DYI folks like us fooling with their AC systems when so many mechanics have spent thousands of dollars on machinery to reclaim refrigerants and so forth. It's such a huge profit margin for them too. Here is one very important lesson that I've learned by working with the AC systems on my cars and trucks: DO NOT BUY A REMAN CONPRESSOR! THEY ARE WORTHLESS! Spend a few more dollars and get a brand new compressor. It's not important how I know this.
Dave |
#8 | |
Re: AC Orifice Tube
Re: AC Orifice Tube
Yup, that mushroom shaped copper/brass thingy is the Thermal Expansion Volvo. ...er VALVE. LOL It's often just shortened to TXV. The capillary tube will have a bulb on the end of it that gets fastened up against one of the lines of the evaporator. It's really important that that bulb makes a very good contact with the tube that it is fastened to. I have always used a small hose clamp on it to make sure - which is way better than whatever I've ever seen any factory use. Anyway, it just gets attached to the side of the tube so that it can sense the temperature and adjust the TXV accordingly. So, go get yourself a little hose clamp... unless of course, it's already connected for you.
Dave |
Re: AC Orifice Tube
Some ac systems had a POA Valve or "Expansion Valve". My 83 has the "Orifice" that goes into the liquid line prior to the "Evaporator" to meter the refrigerant. The "Dryer I refer to is a dryer/accumulator that is attached to the outside of the Evap Box. The Vintage Air systems have "Expansion Valves" in their systems & their dryer/accumulator is attached to the Condenser....
Re: AC Orifice Tube
Ok, I just went to the Vintage Air website and had a look. In the photos (at least for the system they show for MY truck - an '86 crew cab) they show the dryer mounted to the condensor. This is definitely then a TXV system and not one with an orifice tube and there is no accumulator. The Thermal Expansion Valve is mounted inside the under dash unit and it's already fitted for you. You won't have to do anything else. Yayyyyy!
By the time a man would go out and buy all the replacement parts to revamp the original factory system, he would only be a few dollars away from Vintage Air's entire kit. I can tell by experience that their prices seem really reasonable - especially if you're upgrading a truck that has never had factory air.
Dave |
Re: AC Orifice Tube
I just spent 75 on custom hoses, 150 on a new compressor, and 35-40 for a accumulator and orifice. not even close to a vintage air system. I have over 1200 in my vintage air system in my 53 belair.
#13 | |
Re: AC Orifice Tube
It's now simple, clean, insulated, and hopefully works as good as it looks. In my case, I plan to keep the truck forever and it's supposed to be 115 degrees here today!!! I think the price will be worth it. I |
Re: AC Orifice Tube
I bought a new Evap, Condenser, Sanden 508 Compressor & compressor brackets, orifice tube, dryer/accumulator and I'm into it for $450.00
I haven't bought the AC lines yet, but I figure about another $100.00 When all done, I'll have a new system for around $550.00
#15 |
Moderator
![]() Join Date: Oct 2008
Re: AC Orifice Tube
You know these don't have dead insects, mud daubers, and old mineral oil that turned to shellac inside em.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#16 |
Re: AC Orifice Tube
Ok I got a question. Why don't my V/A kit use any hardlines? It's hoses, 100%. I'm assuming technology has evolved and the hoses don't collapse on the suction side? Or, is it a durability issue on mass produced vehicles?
#17 | |
Re: AC Orifice Tube
There are so many different hard lines out there, it would not be cost effective for an aftermarket company to make them. Even the Vintage Air I installed in my 63 Impala has all rubber lines.
#18 |
Re: AC Orifice Tube
Yes, and if you think about it, hard lines are made for production cars that have their routes already mapped out. All rubber lines can be very flexible making installations in a variety of vehicles possible. Interestingly, the mobility van that I use to carry my parents' wheelchairs has a front and a rear AC. From the compressor back to the rear, all the lines are rubber - no hard lines at all.
Dave |
#19 |
Re: AC Orifice Tube
Rock Auto Four Seasons 54275 Evap $53.79
Four Seasons 33204 Drier/Accumulator $13.75 Spectra 73642 Condenser $72.79 Four Seasons 26739 O-Ring kit $3.83 10% discount $7.21 Shipping $16.98 Amazon Four Seasons 38635 Orifice Tube $5.61 free shipping Ebay Sanden 508 Compressor $119.00 free shipping Summit Vintage Air Side-Mount Compressor Brackets 151370-BCA $101.00 freeshipping total $493.96
