Kit for better handling and lowering
1970 stepside/shortbed. Disk brakes in front. 6 lugs wheels all around.
Is there a kit that you can recommend that do fix better handeling and lower the car 4’’/5’’ (or something like this)? |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Kit for better handling and lowering
There are kits available...Check LMC Trucks out...The biggest handling improvement will come with adding a front sway bar. The first move in lowering your front end should be with "drop spindles"...That way the steering geometry, caster and camber are not affected with the drop. The rear can be done by simply adding "drop springs" up to 4" and maybe 5" on a short bed and bending the panhard bar. I put a 15* degree bend in my panhard bar with 4" drop springs and the rear end is centered perfectly. I can still haul my 600 lb KZ1000 (drag bike) without bottoming out. If you go over 5," or 4" on a long bed, you will need to relocate your shock mounts and opt for shorter "shorty" shocks as well as either bend or install an adjustable panhard bar. LMC is your friend...~Ghostrider~
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#3 | |
Still plays with trucks
Get a set of four polyurethane sway bar bushings & brackets that have the grease fitting on them and are the thicker overall bushing diameter. There are versions that have a thinner wall thickness that will not work well in our trucks with the design that bends them under suspension travel. A kit designed for a square body with the 1-1/4" bar should be the correct ones. Absolutely replace the trailing arm bushings with polyurethane parts and get new bolts for them. Those bolts have seen 50-years of constant hammering and exposure to the elements. Do you really want to risk damaging your truck over $20? While you are working on them stitch weld some 1/8" plate to the top & bottom flanges of the trailing arms and wrap it around the back end. Not much added weight but it will substantially increase the strength and durability of the trailing arms. It may not sound like much but replace your rubber body bushings with a set of polyurethane ones and get new bolts if the kit doesn't come with them. It won't make the truck handle better but it will make it more responsive to your steering input similar to a quick ratio gear box does. Same goes for replacing rubber shock bushings with polyurethane for a similar reason. Just getting lowering springs isn't what you need. You need to talk to somebody like Rob at No Limit Engineering about proper spring rates for the handling you are after to go along with the spring height change you want to get your desired ride height. There is a science to it that can make an otherwise well put together truck drive like a shopping cart if done incorrectly. Shocks have a ton to contribute to it as well. Too much shock rate is just as bad as too much spring rate. Off-road 4x4 shocks on a street truck will make it drive like you put a piece of schedule-40 pipe in there instead of a set of shocks. A set of Koni reds have always been my starting point on a great handling street bound vehicle but there are many other great performance shocks out there. Get a set of double adjustable shocks if it is anywhere in your budget. The ability to tune them to your specific application is invaluable.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Try ECE. They're well known here and are well regarded. Forget LMC hahaha
https://www.earlyclassic.com/catalog..._tid=140&keys= https://www.earlyclassic.com/catalog..._tid=140&keys=
72 C10 lwb fleetside -stock 350/350 combo |
This rear sway bar makes a huge difference http://www.classicperform.com/Store/...uck/CP7401.htm
