Old 06-23-2018, 06:46 PM   #1
Lancialonnie
Active Member
Tilt Steering Column Help Needed!
I am not sure what tilt steering column is on my truck but it apparently is not originally from a 72 truck as most of the replacement parts I have ordered do not fit.
Name:  steering column.jpg
The steering rod end is splined and it has this coupling unit and a rag joint at the PS pump.
Name:  steering splined shaft.jpg
I bought an aftermarket tilt column that has a 3/4 in DD on the end, is there a way to make this setup work? Do I need a DD to splined adapter? Do I need to keep the coupling unit since I have a rag joint?
Name:  steering D shaft.jpg
Any advice appreciated!
Lancialonnie is offline   Reply With Quote
Old 06-23-2018, 10:13 PM   #2
StingRay
StingRay's Avatar
Re: Tilt Steering Column Help Needed!
The first one looks like a stock column to me. The second one is the same type of shaft as later columns use. I have a stock type column around here that uses that same D end on it. Came from a later RV I believe. I found an intermediate shaft and coupling at a wrecker that fit it.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 06-23-2018, 10:42 PM   #3
FirstOwner69
FirstOwner69's Avatar
Yours looks like an original truck tilt to me also. What parts have you ordered that don't fit?
FirstOwner69 is offline   Reply With Quote
Old 06-24-2018, 12:44 AM   #4
StingRay
StingRay's Avatar
That original column is worth some coin too!
Canada
Old 06-24-2018, 01:41 AM   #5
Lancialonnie
Active Member
I've ordered 2 turn signal canceling cams that did not work and a shift lever that did not fit. Is the coupling unit assembly after the spline needed?
Old 06-24-2018, 05:38 PM   #6
Boog
laying low
Boog's Avatar
I'm curious why you would want to replace a factory tilt column. There is only one shift lever for a 71-72 tilt column. It is different than for a non tilt column.
https://www.classicparts.com/Dash-Pa...ducts/268/12/0
And two horn contact rings for tilts.
https://www.classicparts.com/Dash-Pa...oducts/268/6/0
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-24-2018, 11:21 PM   #7
Robznob11
Robznob11's Avatar
Dude, unless you bought one of the big 3 columns, Ididit, FR, BS....you need to abandon your idea to swap. As mentioned that oe colum is worth coin, and much better made than the cheap overseas crap running around. There is plenty of write ups of those coming apart. And being loose. The plastic ball they use sux and will fail prematurely.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 06-25-2018, 12:04 AM   #8
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I would pass on any Flaming River columns as I have installed one and a buddy has one and they are not worth the metal spent to make them. Very sloppy......
I have a 72 tilt on the ground from my motor home that I can take a pic to show you what it should look like if you want. Also have a Van Tilt here.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 06-25-2018, 01:35 PM   #9
randy500
Your factory tilt column has a non tilt turn signal switch installed, order the cancel cam for non tilt.
Like someone said previously, order a shift handle for a tilt column.
randy500 is offline   Reply With Quote
Old 06-25-2018, 02:33 PM   #10
StingRay
StingRay's Avatar
That makes sense. The Red 4 Way knob is only on the non tilt. It should be the black cone or the later black round cylinder with the sleeve.
Canada
Old 06-25-2018, 10:53 PM   #11
Classic Bowties
Always on the hunt...
randy500, that last part of your statement is bad info for the original thread poster. No matter the type of t/s switch found installed on the tilt, the horn contact-t/s cancel cam has to be for a tilt column. See below pics, the OE tilt columns used a tilt specific t/s cancel cam and tilt only cam spring. The below linked older thread also has some good info along with pics pertaining to this same subject. Mel
Horn contact/cancel cam thread link: http://67-72chevytrucks.com/vboard/s...d.php?t=515103
Classic Bowties is offline   Reply With Quote
Old 06-26-2018, 01:33 PM   #12
Classic Bowties
I was going to mention the spring and horn contact but you can see them in them installed in the first picture. Looks like he is covered on that.
Again, my above posted comment was only addressing the last part of your below (in bold) instructions/reply to the original thread starter Lancialonnie. A whole lot of folks look back upon these board threads for info and guidance, so if/when I see incorrect info or instructions added I will always try and note/add the correct info. Mel
Old 06-26-2018, 02:51 AM   #13
randy500
Old 06-27-2018, 11:48 PM   #14
Lancialonnie
Active Member
Here are some pics of the shift lever that specifically said was for a tilt column, but it does not fit. Looking at it again it looks like with some grinding and filing, it should fit but I should not have to modify a part that is supposed to fit. I read the articles about the chinese columns and the one I bought is made in china but it is aluminum and looks to be well made. I called the vendor that I bought it from and they sell an adjustable shaft/u-joints/splined adapter for the steering box. No rag joint but the rep said he has ran this setup before without a problem. I have to admit I am on the fence but I do want turn signals that work, a shiny non-rusty gear selector and a shiny chrome aluminum column would look nice!
Old 06-28-2018, 12:20 AM   #15
FirstOwner69
I, also, had to do some "grinding and filing" to get the lever I bought to fit into place. It didn't take much and is not visible. It was almost as if they didn't allow for the thickness of the chrome plating. Once done, it works fine and looks great. To me, it was a minor inconvenience, but you are right, modification shouldn't be required.
Old 06-28-2018, 12:14 AM   #16
randy500
There are nothing but terrible reports about those Chinese columns, they wear out as soon as put in service or sooner. Just put it on the shelf and don't throw any more money at it.
As for the shifter...there is a spring inside where it is inserted, towards the dash side, are you jamming the shifter up against the spring and it wont insert fully or it doesn't fit the hole? The shifters in the picture appear to be interchangeable.
I cant make out what the item in the first picture is.
