Old 11-13-2003, 06:54 PM   #1
dubie
dubie's Avatar
did our year of trucks come with a 10" clutch
I'm sure my engine is stock and has a 10" clutch, but I was just told different. A guy at another parts store I just called, told me that the inline 6 in a full size half ton used 11" clutches, not 10. Can anyone comfirm that a 10" clutch is in fact stock in these trucks
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 11-13-2003, 07:27 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I had the 327-3 on the tree in my truck and it came factory with a 11in clutch with a 12in flywheel. I wouldn't think that it would be different if the engine was a I6.
67Fleetsidedream is offline   Reply With Quote
Old 11-13-2003, 08:13 PM   #3
mikeoj
Just replaced my stock 10 in clutch in a 70 C10 6cyl 3spd.Napa told me 10 in cost more because everyone replaces them with 11 in.Mike
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 11-13-2003, 08:53 PM   #4
Class of 69
Class of 69's Avatar
Stock clutch is 10" 11" was a Heavy duty option on small V8, and standard with most 4 speeds. If the flywheel is big enough, and drilled for the 11" put it in. You will never regret it!!
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 11-13-2003, 09:48 PM   #5
TODDS 72
Not the nightly winner
TODDS 72's Avatar
i checked mine today and its a 10 inch
72C10SWB BLUE 350/350
86K10LWB BLUE 5.7 700r4 7.5' fisher plow
93S10XCAB4X4 BLUE 4.3 4L60e
69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green
86k15 swb5.0L 4spd brown
TODDS 72 is offline   Reply With Quote
Old 11-13-2003, 10:53 PM   #6
fast_dev
fast_dev's Avatar
my stocker was a 10 also, replaced it with a new 10" and it lasted about a month and fell apart, replaced it with an 11", no more troubles after that.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 11-14-2003, 12:46 AM   #7
Pont
I need another Barley Pop
Pont's Avatar
Not sure what mine came with originally, but I would guess that it was an 11". When I recently replaced my clutch, my parts guy pulled an 11" and had it sitting on the counter when I went to pick up the new parts. However, when someone did the big block swap in my truck, they put a 12" setup in it. I'm happy with the 12".
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 11-14-2003, 04:03 AM   #8
boilrman
70 Chevy 3/4t
when I rebuilt my I6 I replaced the clutch beings it was open and accessable. It was an 11".
Find a job you love and you'll never have to work a day in your life.
1998 Yamaha V-Star 650
1970 Chevy 3/4t, I6 (rebuilt), 4 speed
Kokomo,IN
boilrman is offline   Reply With Quote
Old 11-14-2003, 05:39 AM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
My '68 C/10 stepside came optioned w/292 L6, SM465 4-speed and 11" clutch.
Old 11-14-2003, 09:53 AM   #10
JJR
JJR's Avatar
I know the standard clutch for a 250 is 10". My 70 C-10 with a 250 came with the heavy duty clutch option which is 11" for a 250. I was under the impression that V-8's came standard with an 11" clutch and a heavy duty clutch was a 12". As noted above if you have an 11" clutch you can upgrade to a 12" using the same flywheel. Hollanders only shows one flywheel for V-8 applications which is the 11"/12" clutch. The V-8 flywheel (used on most Chevy truck and cars to about 1985) is the same one used on the 250 with heavy duty (11") clutch.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 11-14-2003, 05:38 PM   #11
chaptr2
chaptr2's Avatar
My old 71 with a 307/4-speed was 11", my 72 Blazer/4-speed is a 11", and my 70 GMC was a 11" all were factory. In 1993 I bought a lifetime warranty clutch from a national parts chain and have used the same receipt for all my trucks. They have all been the same 11 inch clutch.
This is only my opinion and it is subject to change.
70 GMC Short box stepside Blown 388 Stroker
72 K/5 Blazer 350/SM465/205
chaptr2 is offline   Reply With Quote
Old 11-14-2003, 06:10 PM   #12
dubie
dubie's Avatar
FINALLY found a 10" clutch kit. I swear to god that it must be a bastard clutch size up here.
I have a clutch kit on it way over night to me, so I can install it tomorrow morning. I am using a replacement 10" to put on my 350, since it's just a summer cruising truck, i don't need anything heavy duty.
Oh and it's cost me $50 less than the 11" that I was sold
