Old 07-09-2018, 07:33 PM   #1
andrewpclayton
andrewpclayton's Avatar
vortec 5.7 and 1969 SM465
will 1999 vortec 5.7 mate directly SM465 trans from 69 c15 mate directly together? Do I need some sort of adapter? I would be replacing a 307 which i believe to be original to the 69 truck.
forgive me if I am not asking this question correctly as I have little experience in this arena...
1977 SWB (c20 conversion) SBC350
Springfield Oregon
Instagram: @nevernotchevy
andrewpclayton is offline   Reply With Quote
Old 07-09-2018, 09:02 PM   #2
6T7 C10
Re: vortec 5.7 and 1969 SM465
You will need a flywheel from a 86+ compatible with the one piece rear seal. (I think as I have not done this combo personally.)
6T7 C10 is offline   Reply With Quote
Old 07-09-2018, 09:30 PM   #3
Chilly178
Chilly178's Avatar
Flywheel you need if running 168t already. https://www.summitracing.com/parts/n...8648/overview/
Chilly178 is offline   Reply With Quote
Old 07-11-2018, 09:11 AM   #4
clay68c10
clay68c10's Avatar
Check the block and see if it has the boss cast in for your clutch linkage pivot
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-11-2018, 09:33 AM   #5
clay68c10
clay68c10's Avatar
Here’s a pic of an 880 block I have setting for future use. Looks like maybe the boss is there, I don’t remember where the pivot ball mounts. I haven’t looked for one in a while, I’ll be running a hydraulic clutch when I put in the TKO.
13 Tahoe LTZ
Old 07-11-2018, 10:41 AM   #6
4carbcorvair
I have a TBI 5.7 and had an SM465 (now have an AX15) in my CJ. later one piece rear main seal style flywheel. Pilot bushing. And clutch linkage. Novak adapters sells some different brackets for hydraulic slaves, perfect time to switch to a hydraulic external slave set-up. I made my own bracket
68 K20 Custom Camper/CST Wrecker.
97 GMC K1500 short bed reg cab.
4carbcorvair is offline   Reply With Quote
