07-11-2018, 03:03 PM | #1 |
Cross Member Question - Why
What is the purpose of the odd cut outs on either end of this cross member?
Is it to reduce stress\stiffness?
1968 GMC truck 910 Trim (Canadian) 127" WB 3 on the Three Trans (Saginaw SM330) 250 ci L6 Engine HEI ignition (early 80s L6) |
07-11-2018, 03:27 PM | #2 |
Re: Cross Member Question - Why
The e-brake cables run thru there, that's the only purpose I see.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
07-11-2018, 04:39 PM | #3 |
I'd say so that it can be installed. Tolerances are such that it's tough to make a part of one piece that will always fit internally. The cut outs let it flex outward or inward and then it gets riveted in place.
Saskatoon, Saskatchewan Canada |
07-12-2018, 02:07 AM | #4 |
67-72 parts collector,…
Wiring?
Fuel lines? Brake lines?
07-12-2018, 08:52 AM | #5 |
Who's got steelies?
GM called this alligator jaws in their brochures....
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
07-12-2018, 07:54 PM | #6 |
why the glass pack and then regular muffler
07-12-2018, 08:05 PM | #7 |
07-12-2018, 08:40 PM | #8 |
Who Changed This?
Those are for weight reduction.
07-12-2018, 11:07 PM | #9 |
I'd put my money on frame twist so the x-member won't tear or crack
07-13-2018, 02:05 PM | #10 |
Glass pack was on when I bought it. I wanted it quieter. Threw a muffler on the back.
Funnily enough it sounds good now. I have 2.25" stainless pipe and a magnaflow on the way. It's low on the priority list right now. Rebuilding the cab is time consuming.... In the driveway no less . Waiting for the neighbors to complain.
