Old 07-13-2018, 10:09 PM   #1
MidLifer
MidLifer's Avatar
4L80e drops out of drive to D3
I am using a stock auto column from 67-72 with the Lokar rod shift linkage on my 6.0/4L80e. Whenever I get on the gas, the engine torques enough in the mounts drop the trans out of drive into d3 and I have to shift it back to drive after I let up on the gas. Advice on how I can fix this? Anyone else dealt with this?
MidLifer is offline   Reply With Quote
Old 07-14-2018, 10:14 AM   #2
Clyde65
Clyde65's Avatar
Re: 4L80e drops out of drive to D3
Change to Locar cable??
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-14-2018, 12:15 PM   #3
MidLifer
MidLifer's Avatar
I guess that’s one option. Was hoping not to have to spend $150 though.
Old 07-14-2018, 04:10 PM   #4
ls1nova71
ls1nova71's Avatar
Good grief, what kind d of motor mounts are you using???? Sounds like what happens when one is broken. You could always use a cable to tie the engine down I guess...
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-14-2018, 05:28 PM   #5
truckdude239
truckdude239's Avatar
i was going to say sound like u have a broken mount , on my 71 i have the stock linkage and and motor mounting and mine doesnt flex at all
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-14-2018, 06:26 PM   #6
MidLifer
MidLifer's Avatar
Engine mounts are fine, they are CPP. The trans is mounted to a CPP crossmember. All bolts are properly torqued.
Motor may not be torquing much at all, in neutral it doesn't move a millimeter. The shifter moves very easily (had the pan open recently to change the internal harness and no, the internal detent mechanism isn't broken or bent either) and since I"m using a stock column, the detents on the column don't quite match up (when in Drive, the gear indicator shows between N and D) and the stock shift lever is heavy. If I support the shift lever while accelerating this doesn't happen. Could just be the weight of the shifter and some slight movement (remember, motor mounts and trans mounts have some rubber in them) that is enough to move the shifter.
So please, save the grief for someone who died. I'll call Lokar and ask them what they recommend.
Old 07-15-2018, 11:15 AM   #7
72MARIO
72MARIO's Avatar
My suburban will pop out of reverse when backing up tye camper trailer. I am thinking a cable or stock type shifter is the answer.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-15-2018, 01:12 PM   #8
MidLifer
MidLifer's Avatar
That’s another behavior it exhibits sometimes.
I’ll report back on what lokar says. Might just have to switch to cable.
Old 07-17-2018, 09:44 AM   #9
Hart_Rod
Hart_Rod's Avatar
Sounds like it just needs some adjustment...
Hart_Rod is offline   Reply With Quote
Old 07-17-2018, 09:58 AM   #10
MidLifer
MidLifer's Avatar
That is exactly what the tech at Lokar said. Put both the trans and shifter into fully-detented Drive, then adjust the rod so that the bolts are 90 degrees. Gonna give that a try.
Old 07-26-2018, 02:30 PM   #11
MidLifer
MidLifer's Avatar
Just to report back and close this thread out - I followed Lokar's recommendations and adjusted the rod with both the trans and the shifter in D. Problem disappeared. Truck stays in Drive no matter how hard I get on it.
