what this plug for?
I had this loose in the bay since I changed the wiring. I never come across it when looking so far.
Not sure if this one of the optional wires for the 700R4 hook up. Because I have factory dual set up on this wiring harness both Dist. 4 pin & 5, & the 700R4 trans. 1984 GMC 305 700R4 1/2Ton Where does this go to?. ![]()
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
OutOfMyMind & I'llNeverKnowWhy
Re: what this plug for?
EGR solenoid?
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
The EGR is vacuum operated. I do not think there was a solenoid on it that I know.
where was the solenoid located ?
An 84 305 came with an EGR solenoid from the factory. It would help control vacuum going to the EGR valve. It was located to the right side(passenger side) of the distributor.
Moderator
![]() Join Date: Oct 2008
EGR solenoid has different color wires and a different connector.
Harness came from a Manual transmission truck? The ESC 1st gear switch on a 1984 manual transmission truck has a two-terminal Weatherpak with Green and Yellow wires. Yellow goes back to the ignition Crank wire just before the Clutch interlock and Green goes to the ESC computer.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 07-17-2018 at 07:28 AM. |
hatzie Qoute:EGR solenoid has different color wires and a different connector.
Harness came from a Manual transmission truck? The ESC 1st gear switch on a 1984 manual transmission truck has a two-terminal Weatherpak with Green and Yellow wires. Yellow goes back to the ignition Crank wire just before the Clutch interlock and Green goes to the ESC computer. Answer: The Truck is a 84 GMC 305 Auto, None A/c Truck had duel set up Dist. set ups 84 had a TH350 in it no motor. I got the cab, clip witch the clip is mostly on my 77 and the wiring harness still has the computer. I have not seen the connector before yet. I not sure if it's a Factory Plug. Wire green & yellow look's like 14ga
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 07-20-2018 at 12:38 AM. |
I wonder if the truck had dual wiring Trans set up too, since it had dual Dist. wiring set up too. That would explain why most 84 trucks when I was looking for it was on A/T
not a lot truck had this set up.
Moderator
Download the 1984 wiring diagrams. Not very many Weatherpak plugs in that year harness period.
Get your meter out and set it up as a continuity buzzer. Does the yellow wire ring out the neutral safety switch? Does the green wire ring out to the ESC computer?
And please let us know if and how your repairs were successful. |
#9 | |
| Bookmarks |
